Question about Peavey Escort 3000 300 Watt Portable PA Speaker System
Having problem opening and closing speaker stands. Is this normal?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
If you are not good at it
Posted on Jan 15, 2013
How do i open case to repair power supply
dgx screws are so many..u have to open the speaker covers there are other screws inside...which u can only access by oppening the speaker back cover...you will also have to open the silver screws..all of the behind the cover..all this u r doing when you have separated it from the stand. place it on a mattress in need be to avoid accoustic wear.
Sep 25, 2014 | Yamaha DGX630 - Digital Piano
My Mackie Thump TH-15A will not produce any bass. I can get some sound but only from the top tweeter. Whats wrong and how can i fix this?
Could be the crossover has died or the main speaker winding has failed. Open her up and connect on side of the main speaker direct to a 9v battery and then wipe the other wire over the other terminal. If you get a crackling from the speaker then it's likely the crossover, if there is no response at all from the speaker then it is dead and possibly the crossover too.
Sep 23, 2013 | Mackie TH-15A Active DJ Powered THUMP...
Hard to open and close speaker stands. Is this normal
There's a number of lubricants that should alleviate your pain to open the stands with ease and certainly you should use one.
Jan 15, 2013 | Peavey Escort 3000 300 Watt Portable PA...
External Speaker hookup problem. I hooked up 2 external speakers (8 ohm, 160 watt) into my Marshall AVT 50 amp (tag on back says 4 ohm minimum). Everything worked fine, then I shut it down and now (next...
If you are competent with electronics, open it up and check the fuse(s). Especially if no lights come on. If you get voltage, then check the jacks you plugged into- they may have dirty interrupt contacts. When you plug the jack in- it opens those contacts that otherwise are closed making the circuit to the cabinet's built in speaker. Contact cleaner should clean them up if that is the issue.
While it is possible there is a power supply issue, you can see that quick with a voltmeter, it is not likely you did much more than blow a fuse.- very possible if you unplugged speakers with the amp operating..
If you think you killed it- you usually still get distorted noise.
Mar 29, 2012 | Marshall Amplification Music
How do I fix the plastic jack inside the speaker? It seems loose, yet it connects fine, but still doesn't work. The wiring is fine.
Open the speaker and either secure the jack or replace it if it is broken... common problem when cables get tripped over.
Jul 19, 2011 | Peavey 00511800 Escort Portable Sound...
I have a Roland FP 1 digital piano, serial #AL21141N. It has gradually quit putting out sound through the speakers. At the onset of the problem, I could fit it by jiggling the 1/4" speaker plugs,...
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Jan 14, 2011 | Roland Digital Piano FP4 Black With Stand...
Proline Piano Keyboard Stand Assembly Hi, I just bought a Proline piano stand for an electronic keyboard, and the first step on the assembly directions is to move the clutch to the middle position....
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Nov 28, 2010 | Pro Line Proline Pl 400 Double X Braced...
Hook up extra speakers
Most of these portable PA systems do NOT have amplifiers capable of driving extra speakers SAFELY without risk to the amp.
I would NOT attempt to drive more speakers without using another amp to drive those speakers.
Sep 19, 2010 | Peavey 00511800 Escort Portable Sound...
My amp is not outputting to the built in speaker. I can get output to headphones and have proved it with both guitar and ipod but neither work to the speaker.
Possible problem with teh switch on the headphone jack wooould be my guess. When you plug in the headphones it opens a switch to disconnect the speaker. Unfortunately, these jacks are weak and often the switch fails to close when the hedphones are unplugged.
You need to open the amp and check if you can close the contact by pressing on it. There are several designs of these jacks and MOST are weak and having a cord plugged in and tripping over it is SURE to break the jack.
Here is a site showing jacks for a Fender, but most are similar.
Look at the one with several strips of metaal between the little black walls... they are NOTORIOUS for the switches not working. OFTEN you can bend the springs tigter to restore them. The site with pix in a box at the top:
http://www.catalinaguitars.com/catalog2/index.php?cPath=66_86
Dec 19, 2009 | Marshall MG10CD 10 Watt Combo Amplifier
Peavey Escort 3000 300 Watt Portable PA Speaker System Logo
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
