Question about LG W2442PA-BF 24" Widescreen LCD Monitor
Need driver for LG flatron W2442PAT as it suddenly stopped duplicating laptop display
Worked great for a year. Now when i try to set it up in control panel display #2 ie external monitor is given the same name as the laptop display. Do i need to download drivers?
SOURCE: LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Posted on Jul 27, 2007
tomhar
  • 20 Answers
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Posted on Mar 08, 2009
pandeyram1
  • 192 Answers
SOURCE: I need a driver for the LG Flatron L1919S LCD
for what purpose you want the driver for the monitor? generally there are no need to install the monitor driver.
Posted on Apr 01, 2010
lyonzy1
  • 208 Answers
SOURCE: Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
Posted on May 20, 2010
SOURCE: LG Flatron F900P Monitor
Just press select button for select correct input connector. PNP no driver required.
Posted on Oct 04, 2010
LG 55LX6500 55 inch LED TV display gone, but sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 02, 2016 | LG Televison & Video
Nosound on lg flatron w2442pat
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
http://www.wisiny.com/eay38422105aip-0178a-lg-eay38422105-power-supply-backlight-inverter
Feb 13, 2013 | Computers & Internet
Can't start up. suddenly stopped working.
hi, please check the setting first of the monitor, their is a setting their that it will when it set up time is to turn off or stand by..
Mar 19, 2010 | LG FLATRON L206WTQ-BF Monitor
I can't get my new LG W2242TQ to display in full screen. Do I control this on the monitor or though software. I have been trying both. Help.
How is it hooked to your computer. It may need drivers but you very well may be able to set it from display manager. R-clickon your desk top and go to properties and change the settings this may help get you the full dispsly. WHat operating system are you running
Apr 17, 2009 | LG 22" FLATRON LCD Monitor
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
No picture
you should take it back
Jun 21, 2008 | LG Prada KE850 Cellular Phone
Jul 25, 2007 | LG Flatron 775FT 17" CRT Monitor
Cant get 1280x1024 when connected to laptop
the only way you may get it to work is if you use the monitor a secondary device and also use the notebook monitor as well. But the problem may also be the vga connector converting the signal, as you may have to have a DVI connection on your monitor to obtain widescreen resolutions.
May 28, 2007 | LG Flatron L1710B 17" LCD Monitor
Power Saving Mode during game play only
I've got the same problem but it only occurs with one, older game.
I run a Radeon 8500.
Nov 03, 2006 | LG Flatron L1715S 17" LCD Monitor
LG W2442PA-BF 24" Widescreen LCD Monitor Logo
46 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
