Question about Lenovo b560 Notebook
Keyboard won't work - Lenovo b560 Notebook
  • Lenovo Master
  • 27,725 Answers
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Posted on Jan 15, 2013
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
Plug it in and reboot computer, if it is usb reinstall drivers for usb and/or keyboard, if it is wireless, put batteries in it,
i mean for heavens sake you people,
write some information in here, are you people that dumb?
what kind of keyboard is it, brand, keys, ps2, usb, wireless,
some information say, this is it?
my car won't start, why not? duh, give me a break
  • lajilbert
    lajilbert Jan 15, 2013
    I appreciate the help but don't like being labeled dumb. The keyboard is the built in one that came with it. I fixed this problem before by uninstalling aface scan feature. I have tried rebooting several times anf all fn keys suggestions I have found. The keyboard willwork to let me log into Windows but not after that .
  • Brian Sullivan
    Brian Sullivan Jan 15, 2013
    yes this ed greason has labelled people as dumb when all he need do is to READ its a LAPTOP keyboard is inbuilt give me a break huh
Keyboard will not work in dos lights will light up then goes off?
1st Check the PINS when u plug it in - I guess you are using a PC
2nd If its a USB Keyboard - try using a PS/2 - the one which has a purple end and some pins
3rd The light flashing on and off is ok - its a test - however you have the option like F8 / DEL by pressing repeatedly it will show you a BIOS Setup where you can change keep NUMLOCK light on. - this will help you know if the keyboard is detected correctly or not.
Nov 16, 2017 | Computers & Internet
Keyboard won't always work on start up
Try a different keyboard. If you're currently using a ps/2 keyboard, then for sure get a usb keyboard.
Jul 25, 2012 | E-Machines W6409 (7234) PC Desktop
My logitech keyboard won't work.the mouse is ok
If your keyboard led is not lighting up when you start the computer, there might be a problem with your conection between your keyboard and the port at the back of the computer.
Feb 18, 2012 | Logitech Computers & Internet
Keyboard won't work
Hi
Try uninstalling the keyboard and installing it again.
Hope it helps.Thanks
Feb 18, 2012 | Logitech Wireless Access Duo Optical...
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
My f10 lite is on and keyboard won't work
Unplug it and replug it, if it still doesn't work restart your computer. If it still doesn't work, it could be the keyboard, or it could be the port it's connected to.
Aug 23, 2011 | Computers & Internet
Need a keybored
If you have a desktop computer system you can find keyboards at nearly every retail store. Any keyboard will work on any computer. (Well, this may not be 100% true. If your computer only has USB ports and no PS/2 style connectors - true for a few systems - you'll need a USB keyboard. Otherwise you can plug in anything.) There's no need to stay with the exact same keyboard that was supplied with your system, unless it had special-function keys like volume control or Web access. Even then you can buy keyboards with special keys, and they will come with the software you'll need to make them work.
With laptops it's a little more difficult since the keyboard needs to be an exact replacement, otherwise it won't fit the case and the connection to the motherboard won't be right. But there are many sources now, and for popular brands a lot of low-cost generic replacements are available. You don't always need to buy the original keyboard from the manufacturer. I find eBay to be a good place to look for keyboards (and other laptop components as well). I've found my last few keyboards, batteries and some display hinges from eBay sellers at good prices.
You haven't said what make and model computer you have so I can't be any more detailed. I hope you find this general information useful and that you get a new keyboard quickly. Thanks for using FIxya!
Jun 23, 2011 | AMD Computers & Internet
Sustain pedal doesn't work any more - maybe it isn't the fault of the pedal? I don't want to order a new one if the problem is in the keyboard. I'm sorry, I just lent it to summer guests...
take it into a music store and try a pedal there in store. If it works, buy the new pedal and charge the guests. If it does not work, you know it's th TS input on the keyboard
May 20, 2011 | Casio WK110 Portable Keyboard
Hello. I have an Acer Aspire 5517. And just recently, out of nowhere, a few letters do not respond. Like the letter "t" won't respond. And a few others. This happened completely out of the...
Hi vay_m0u8 ,
This is an indication that your keyboard is going to be out of order in some time.
All you need to do is to get the keyboard replaced if it's under warranty or follow the procedure below to check if it works.
  1. Open your keyboard , (Only if it's not under warranty) and then with a soft cloth clean the circuit present inside , you can use liquid like petrol for good cleaning.
  2. Once you have cleaned it , close your keyboard and then , check if it works fine.
  3. If the problem persists , either get a new keyboard , or get a replacement , if the keyboard is still under warranty.
Hope this helps ..:)
May 19, 2011 | Acer NSK8458AN Keyboard
Lenovo b560 Notebook Logo
216 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
