Question about Dishwashers
Kenwood kdw60w10 not heating water
Will it be the thermal resistor or heating element
2 Suggested Answers
  • 45144 Answers
SOURCE: kenwood dishwasher kdw60w10 heating element is no longer working. can i replace element with a hotpoint or beko one?
An appliance parts supplier can advise you regarding interchangeability of heating elements.
Posted on Jan 23, 2015
Kenwood dishwasher kdw60w10 heating element is no longer working. can i replace element with a hotpoint or beko one?
Jan 23, 2015 | Kenwood Dishwashers
Wd51 drying not heating
there are a few things that can cause the dryer to not heat there is a one time thermal fuse that can blow causing the heating element to not function . one cause of this thermal fuse to blow (in this case heat) would be the lint in the dryer vent tube it clogs the tube then the heat builds up by the heating element and blows the resistor this is very common . One other problem that can occur is the heating element could get burnt out and short out .after some years of use the wire come out of its normal shape and move around and eventually touch the side of the metal housing causing the element to open or break. you can check out this site www.repairclinic.com and put in your model number and find the thermal fuse kit should cost around 22$ the heating element can be from 60 -180$ depending on what type of dryer you have
Nov 24, 2012 | Dryers
Not heating
There are a few things that can cause the dryer to not heat there is a one time thermal fuse that can blow causing the heating element to not function . one cause of this thermal fuse to blow (in this case heat) would be the lint in the dryer vent tube it clogs the tube then the heat builds up by the heating element and blows the resistor this is very common . One other problem that can occur is the heating element could get burnt out and short out .after some years of use the wire come out of its normal shape and move around and eventually touch the side of the metal housing causing the element to open or break. you can check out this site www.repairclinic.com and put in your model number and find the thermal fuse kit should cost around 22$ the heating element can be from 60 -180$ depending on what type of dryer you have
Nov 24, 2012 | Whirlpool Dryers
What does e3 mean on kenwood dishwasher
It means it is not heating the water enough. The manual says.. Longer heating time but not reaching required temperature. The possible causes: malfunction of temperature sensor or of heating element
Apr 30, 2012 | Kenwood KDW243A Builtin Dishwasher
Will not heat, the start light will come on but will not heat
It is probably the thermal fuse that has blown. This is mounted on the base of the iron and requires a near total strip of the appliance. It is mounted in series with the element and looks like a metal resistor, inside a fibre glass woven sleeve. Should the thermal fuse prove not to be the problem it could also be the element itself.
Jul 07, 2011 | Black & Decker Irons
On our AE125, the thermal cut-off is tripping AFTER the water is turned off. The heating element is getting so hot you cannot touch it
The elements are getting over heated then set temperature.You have a defective thermostat. The elements will continue to heat until they reach the set point of the thermostat. Try to lower the temp setting first. If that does not fix it, you'll need to repalce the thermostat, located very near the element, under the screwed cover on the side of the tank.------------- To know how this heater works, read as follows:---
Because electric tankless water heaters have to instantaneously raise the temperature of incoming water to a selected hot water temperature, they require very powerful heating elements. To power the heating elements of this 27,000 Watt model, you will need to upgrade the electrical service you were using for your storage tank water heater. The PowerStar AE125 will require a 240V, 200 Amp service. In addition you will need to install three 40 amp dedicated double pole breakers in your electrical box. In Canada, you will require one 120 Amp breaker.
The PowerStar AE125 electric tankless water heater incorporates a very sensitive flow sensor, and three heating elements. The heat from the electric elements is electronically modulated on the basis of the flow rate of the water entering the water heater, and the temperature rise that the water heater must achieve. Through its electronic modulation system, the AE125 maintains a very precise hot water temperature. As a safety precaution, each of the three heating modules is protected by an electro-mechanical thermal cut-out. This device will cut power to a particular module if the temperature gets too hot.
This will help.Thanks.Helpmech.
Jul 02, 2011 | Heating & Cooling
My coffe maker turns on but nothing comes out, I already checked the spray head & its,not clogged, what can I do
check and make sure the heating pad gets hot if it does not then in the bottom inside the Base you will have to take it apart and under the heating pad their will be some wires their will be a thermal resistor that will be attached to a part of the element this part needs replacing and can be purchased at radio shack for about $1.50 replace it with the new one and reassemble as it was then try the unit. it should be working fine if the heating pad gets hot then you have another issue most likely the water tube come loose at the bottom of the water tank simply re-attach and reassemble some times wile filling the tank when the unit is still hot a steam shock will force the tube off. explanation of the workings the water tank supply water to a tube that attaches to the heating element the water runs though the element heating by the time it reaches the other side it is hot enough to force the water to the top where it is expended to the coffee grounds and brews the coffee like the same way a peculator pot works only difference is the water runs through a tube under the heating element instead of a fire under the pot. hope this helps the radio shack link for the thermal resistor or thermal fuse is the proper name is http://www.radioshack.com/search/index.jsp?kwCatId=&kw=thermal&origkw=thermal&sr=1
chose the proper temp most are for home use at 128°C (262.4°F) Thermal Protector Fuses
Aug 30, 2010 | Bunn VPR Coffee Maker
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
Jul 29, 2010 | DeLonghi BCO120T Programmable Espresso /...
Dryer tumbles but no heat. Replaced Thermal
Howdy: Those are good shotguns. It could be the firing ignitor. Two solenoids control the signal to the element. If thay stick it keeps the element on too long or too shot. Take it down to test at Sears. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
