yes i have same prblem in this samsung monitor lcd model no# 710N they appears on the screen is ( not optimum mode recommend mode 1280x1024 60Hz) I think the problem is the main board but where are the recommended place to buy it the circuit
hi your computer resolution is too high which is not supported by your monitor thats why u get this messqage there is nothing wrong with your monitor please set the display resolution to 1024X768 and it will be fine how u will u do that either use first with anathor monitor or log in to computer in safe mode and reduce the resolution and restart it or u have to remove the driver and reinstall it ..
cheers
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual. Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz" - The monitor turns on but turns off by itself, the LED blinks green. - If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off. - The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable". - The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz" - The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more 220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n 220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere 220499443698
This is a known problem with 710Ns. This link is to a discussion on the subject on hardwarezone http://forums.hardwarezone.com.sg/archive/index.php/t-1878384.html
I have the same, common problem with my LCD. It keeps displaying "not optimum mode"...
(More)
I have the same, common problem with my LCD. It keeps displaying "not optimum mode" message. How can I fix it? How do this trick with adding Ohms beetwen pins 5 and 6?
