Question about Pyle BZDBP212 Car Subwoofer
Amplifier Powers on But Does Nothing!
The problem is, i have an amplifier(1) which has been wired up correctly. The amplifier(1) has been working great but recently it has decided to stop. It powers ok usually indicated by a green LED, but now the LED has turned red. I have checked and changed both of its fuses so they are fine. All other wiring terminals are in working condition. I have another amplifier(2) setup through the same wiring at the moment which works perfectly fine but when amplifier(1) is connected to the same wiring it just powers on with a red LED and there is no output. I prefere to use amplifier(1).
Please can anyone help, lost all my hair trying to figure it out. Thanks
  • ramzmirza Jan 25, 2009
    thanks for the info. I solved the problem. took the amplifier apart and found a blown ceramic fuse on the board. Can get it fixed through the help of a friend though he likes to fiddle with electrics lol. ta anyway
    Problem Solver:
  • 11 Answers
Try finding a better ground some amps are more finicky about ground than others. Try running a wire from the ground on your battery to the ground on the amp if this works then you will know you need to find a better place to pick up a ground.
Posted on Jan 25, 2009
Get sound on radio install.
Your 2004 Vibe may have been equipped with a radio or a radio and separate amplifier. The BLU/WHT wire supplies +12 V to the radio. The radio ground wire is BRN. A GRY wire powers dial illumination. The BLK/WHT wire you mention is either the antenna input or a sensitivity control input to the amplifier. There also may have been a WHT mute control wire connected to the amplifier. The Vibe has an antenna amplifier which needs +12 v. The aftermarket radio should have separate LF, RF, LR, and RR outputs to connect to the corresponding speakers or amplifier inputs.
Sep 13, 2016 | Cars & Trucks
I have a dual xpe2700 amplifier and it's connected correctly bit the little triangular shaped light won't turn blue like when it does when it on an idk what's wrong with it or what to do to make it work.
How are you certain that you have the amplifier connected properly??
1. 12 volt constant wire should be run directly to the car's battery. MAKE SURE WIRE IS FUSED PROPERLY WITHIN 10 INCHES OF THE BATTERY!!!!
2. Chassis ground wire can go to any heavy bolt close to where your amplifier is mounted.
3. Remote turn on lead comes from the radio harness.
I suspect that this wire may be missing in your case.
If all wires are connected properly AND you do not have a low voltage battery condition than your amp may be nothing more than a shiny paperweight now.
Dec 21, 2010 | Car Audio & Video
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Visonik V1201A 1-Channel AB Amplifier Problem
in that case check all the wiring to make sure it is correct
Apr 15, 2009 | Visonik V1201A Car Audio Amplifier
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Amplifier does not work
remove the speaker wires and re-test. If the amplifier powers on, without fault, you know the sub(s) and/or wiring are the culprit. If the power and ground are ok, take the amplifier in for service. The indicators are there to let you know of a problem. If it is an internal one, a certified tech will be required.
Dec 17, 2008 | Orion HCCA-D5000 Car Audio Amplifier
My jl Auido 250/1 amp
You may have a bad output on the amplifier. I would recommend taking it to a local electronics repair to have fixed, or visit a local stereo shop - preferably a JL Audio dealer. Visit their website at www.jlaudio.com to find a dealer near you. You can have your amplifier sent in to JL Audio for repair by an authorized dealer and you'll get a warranty on the repair work.
Sep 27, 2008 | Jl Audio 250/1 Car Audio Amplifier
No sound but powers light is green
You need to determine first if sound is getting to the amplifier. Then once you are sure of that you need to run a test to see if the audio is being sent to the first pre amp in the actual amplifier. Once this is done you can determine if the samplifier is actually the problem. If it is you will need a schematic to troubleshoot the device.
Sep 07, 2007 | Jl Audio 500/1 Car Audio Amplifier
MY AMPLIFIER
HI SOUFBOY , Theres a few things you need to check , First make sure that your amplifier is getting an audio signal form your head unit,Check all the wires for breaks in the amplifier input, secondly make sure that your 12 inch woofers are still connected to the amp check all the wires . Thirdly check your woofers are they blown ? . The best way of grounding your amp is by scrapping all the paint on a spot on the car body inside the trunk or wherever you have it and making sure the ground wire is securely screwed onto the car body on that spot ..
Mar 19, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Pyle BZDBP212 Car Subwoofer Logo
136 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
