Question about Whirlpool 21.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Water probably condensation in Fridge, has top freezer and lower fridge
Water forms on top shelve in fridge, easily removed, also reaches bottom left side of fridge, easily removed. Condenser and area have been thoroughly cleaned. Fridge and Freezer maintain good temperature, unit is 8 yars old
SOURCE: Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Posted on Nov 26, 2007
SOURCE: Ice & water dripping in refrigerator
hi , roger here i am a maintenance tech for an apartment complex that just happens to have whirlpool appliances. the way i see it is the most likely problem you have is a clogged drain. if you push the refrigerator out where you can access the back of it you will see a plastic hose that runs from about the middle of the fridge down to the bottom and then dumps into a pan that sits on the top of the compresser. the easiest thing to do is to remove the hose from the pan and blow hard through it or hook an air nozzle from a compresser and blow through it . it should take care of it. also try to avoid turning the fridge up on its max settings. hope this helps.
Posted on Feb 13, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
  • 16 Answers
Seems that you now have to little gas in the fridge.Somewhere on your apparatus there should be a factory tag where it should be info on amount of gas, prod date etc and also which type of gas to fill.
Other thing as fan not running properly,door gaskets leaking can lead to Ice build up.
High humidity and water all over inside fridge.Gas filling procedure.Make vacum(vacumpump)Fill in correct weight (grams or oz)of gas.Anyhow when you must fill gas there is usually a leak in your system and to find that i use liquid nitrogen.For this serviceman is the best option.
Regards. jan(Norway)
Posted on Feb 13, 2009
Maytag317
  • 1136 Answers
SOURCE: leaking freezer into fridge
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
Thakns
Vic
Posted on May 15, 2009
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like...
syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Sep 02, 2010 | Refrigerators
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have water in my refrigerator on the shelves and in some areas it is freezing?
Could be a clogged condensate drain. Since you did not give a model #, I will assume this has the freezer on top. When it goes into defrost, the water cannot go down the drain hose to the drain pan and accumulates as ice in the freezer, below the bottom liner and may drip into the fridge. Empty the freezer and open the fridge door. The open fridge door can help thaw the drain. Remove the screws holding the bottom of the freezer liner and remove the liner. If there is ice below it, the drain is clogged. Remove as much as possible by hand and then use a hair dryer to carefully melt the ice at the back of the freezer. Blot up any water from the melted ice and concentrate on clearing the 1/2" hole in the center back. That is the drain. When you think the drain is clear, check it with a large glass of hot water. This can be take some time. When done, reassemble, but also make sure the fridge is tilted to the back by adjusting the legs at the front bottom corners of the fridge. You may have to take the grill off the bottom of the fridge to do this. The legs screw down to lengthen them. Adjust them far enough down that the fridge door swings shut by itself. This will help the water down the drain before the fridge comes out of defrost, starts cooling and freezes it in the drain hose.
Mar 03, 2010 | Whirlpool Refrigerators
Feb 12, 2009 | Whirlpool GD2SHGX Refrigerator
Feb 13, 2008 | Whirlpool ET1FHTXM Top Freezer...
ok your defrost drain is frozen take the back panel off in the freezer section under the coils you will see a silver pan if its frozen it will be a block of ice you have to remove the ice then make sure the drain and tube are clear all the way to the pan at the bottom you should see the plastic tube on the back of the unit in the center over time algae can grow in the tube blocking it drying the unit will help but soon as it defrosts the tube fill up again and the problem reoccurs you kinda got to snake it out so to speak.the best way to deal with it is to go to lowes or home depot and get a eurka 302 enviro hand held steamer an investment but a great product to have around the house cost about 40 bucks but 1000s of uses
Feb 13, 2008 | Refrigerators
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Whirlpool 21.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
