Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Loose wire Been tugged causing loose wire at handle end of flex
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Needs new cable 20.00 for replacement 0800 294 4692
Posted on Jan 15, 2013
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Reset button
on the ergonomic handle design the vibration will sometimes cause one of the switch leads to come loose. Remove the handle tube. Lay the handle tube flat on a bench or table and remove all the handle screws. Work handle haves apart and you will be able to see if the switch leads are loose. If not, the wires inside the power plug may have become separated by somebody yanking on the cord, rather than pulling the plug. With a meter or test light, you can check continuity between the plug and handle wiring. The only thing left is the motor, but let your local repair guy do this, because it can be a bear to get out and re-installed.
Jan 16, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Loose cord on vacumn
The cord may have a broken conductor inside - shorten the cable by 6" or so and remake the connection.
This is a very common fault caused by repeated over enthusiastic tugging over a long period - the wires inside stretch and eventually break apart. Tends to happen at a "tight" bend point - either close to machine or the plug.
BMW custom Parts
Jun 06, 2012 | Hoover Vacuums
Power Cable wires exposed where it enters handle
Part of your question has been cut off by the FixYa system, but I guess you say the wires are exposed where the flex enters the handle. To dismantle the handle, first remove the handle from the machine and, of course, be sure the flex is not plugged in to the mains power.
Look on the back of the handle - you will see a small screw. Undo that screw and remove it, then you will be able to pull the plastic part of the handle out from the metal part. NOTE: it does not come very far out - just far enough so you can separate the two halves of the plastic part. When you've done that, it's only a matter of removing the damaged part of the flex (noting how the wires are routed inside the handle), stripping the remaining flex to match the bit you've removed, and wiring it in. Fit the two plastic halves together again (one hooks into the other at the top), push them down into the metal part and refit the screw. Job done!
If you need more help, just post a reply here and I'll get back to you soon. Good luck!
Apr 05, 2010 | Sebo X4 Bagged Upright Vacuum
There is no power. fuse checked. I have stripped down the vacuum cleaner but still does not work
Almost certainly there is a break in the wire inside the flex. This happens most often just where the flex enters the handle (less often where it enters the plug). If you have any means of checking for electrical continuity, with the machine unplugged from the mains remove the handle and check for continuity between the pins of the plug and the sockets at the end of the handle. If you can't do this yourself, you will need professional help.
If there is a fault in the flex close to the handle it is possible to remove the flex from the handle, cut off the damaged bit and re-wire the remainder into the handle. To have a professional do this may well cost more than just fitting a new pre-wired handle.
Good luck! If you need more help, just post a reply here.
Apr 04, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
My sebo keeps cutting out while I use it the turns back on when I move the lead about. Its over 5 half years old?
Sounds like the flex is damaged. This happens most often either right near the plug or where the flex enters the handle. There may be no damage visible externally, but still the copper wire inside can be broken. You say that moving the flex about makes a difference, so you will know where the problem is. If the damage is indeed at one end, then you can simply cut the flex and re-wire it. If you need to have someone do it for you, get a firm quote as it may be cheaper to fit a complete new handle (there's no labour cost involved because the handle just slides in). I hope this helps!
Jan 31, 2010 | Sebo X4 Bagged Upright Vacuum
My Sebo X4 does not power up, it worked fine the day before but now there's no power. What could be the problem?
Most likely is a break in the electric flex. This can be internal, and completely invisible from the outside. Alternatively, the cable may be visibly damaged so check it carefully. Internal damage usually occurs at the extremities of the flex, where it leaves the plug or where it enters the machine, it's hard to detect without suitable testing equipment, although simply moving the flex around (with power switched on) will sometimes locate the problem. Depending on your wish or ability to deal with this yourself, there are several solutions. Of course, if the fault is at the plug end, the old plug can be cut off and a new one fitted. If the fault is at the machine end, the handle can be re-wired but the usual solution is to fit a new handle (complete with flex). This is more expensive in material terms but works out cheaper than a re-wire when labour costs are added (there's no labour in fitting a new handle, but re-wiring a handle takes time). If this doesn't help, please post a further comment, indicating how confident you feel about taking the machine apart, and we'll consider other options. Good luck!
Dec 14, 2009 | Sebo X4 Bagged Upright Vacuum
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
NO POWER
The problem is almost certainly a fatigue break in the flex. These usually happen where the flex enters the handle through the rubber sleeve near the on off switch. You will need to cut about four inches off the wire and reconnect it to the switch. To do this, you need to remove the on/off button as you have suggested. If you press the green button down, you will see a tiny slot at the side of the button on the side nearest the handle of the cleaner. You will need to slip a small screwdriver with a blade about 3-4 inches long down the slot, in order to disengage the little hook at the bottom of the button moulding that clips it into the body of the cleaner. This is a real fiddle and you will probably mark the casing in the attempt. I have done it dozens of times and I still end up shaving off the ridges I have made in the plastic so the button doesn't stick when I reassemble it! Once you have done this, you can draw the buttup upwards and take it out. This will reveal a philips screw holding the switch button in place. Unscrew and remove the switch, then cut and re-make the connections after removing the 4 inches of flex. You will need to replace the spade connectors on the wire, or cut, solder and insulate the re-joined wires before re-assembly. If you are handy with a solder iron or have some small spade connectors to use, go for it, but be sure you are competent to make this repair. Usual rules for dumb people apply her folks. UNPLUG from the mains before you start tinkering around!
Mar 12, 2009 | Vacuums
KENMORE pROGRESSIVE WITH DIRECT DRIVE SUCKING NOISE
I had the exact same problem. The port is a relief valve to prevent the motor from burning out if the hose/bag are clogged. Check the main hose from end to end after removing the 3 screws that hold it to the body of the vacuum near the handle. If that's clear then it's almost certainly clogged in the short tube that goes from the beater bar housing to the hose extension (where the flex tube attaches). There are two ways of going about this.
Option 2
(the way I did it) -- Lock the base on the upright position and turn the unit over. Unscrew the 12 or so screws in the black base. You'll need to depress the release pedal when removing the screw at the end of the pedal. Once you have all of the screws removed carefully wiggle the base loose. You do not need to remove it completely to access the short flex tube. Clean it out and replace everything in the opposite order from how you removed it.
Option 1 (what I would do next time) -- Cut a wire coat hanger and make a small 1/2" hook at the end. Bend the straight section into about a 4" radius arc leaving plenty to handle at the end opposite the hook. Carefully snake the hanger down the tube and pull out the giant clump of hair and dirt that's clogging the vacuum.
cheers -- eric
Nov 15, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
19 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
