Question about Compaq Computers & Internet
No bootable device
Screen says, "No bootable device--insert boot disk and press any key.'
    Problem Solver:
  • 9 Answers
Loose connection either power or cable
Posted on Jan 15, 2013
  • Lou Gratacos Jan 15, 2013
    Nothing connected, externally. Internal connection?
  • 733 Answers
SOURCE: bootable
hard drive.
Posted on Sep 24, 2009
  • 794 Answers
SOURCE: My acer one is stating 'no bootable device -
Hi chadvar,
There's a possibility computer is trying to boot from another device. Here's what you can do to set your HDD as the primary boot device:
1. First, turn on the PC and as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
2.If not hit F2 as it starts and enter the BIOS.
3. Then, look for the boot option and set the HDD as the primary boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system. If in case that you'll get the same message then sounds like your HDD is dead. Your disk drive is no longer recognized as a bootable drive.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 26, 2011
net2mani
  • 129 Answers
SOURCE: When i turn on laptop
your pc boot sequence is not set.goto setup and change the boot sequence and set hdd first then you able to boot window. if you want to install windows then set cd/dvdrom first and after installation again change sequence.
Posted on Jul 12, 2011
virtual_a
  • 531 Answers
SOURCE: my acer aspire 5551 laptop isn't starting up its
Hi
Check underneath and use a small screwdriver to open the small rectangular panel with the image of a stack of CDs near it. This is where the Hard Drive sits.
Check to see if the Hard Drive is properly fitted properly docked into its socket and screwed down or held down properly so it is immobile during use.
If this is not the problem, tap the Fn + the correct function key to enter the Boot Menu at Start Up and use the keyboard arrows to select the Hard Drive boot option.
Make sure there is no CD or DVD in the Optical Drive.
If none of these is the problem then, regrettably, your hard drive may have failed, so remove it and test it in a hard drive dock or an external 2.5" Hard Drive Enclosure.
If it has failed you will obviously need a new hard drive, bootable operating system disc, drivers disc and programs and security software to reinstall everything to the new hard drive.
Unfortunately, any data on the old drive will be lost.
It is very unusual for a Hard Drive to fail suddenly without some prior warning or signs of failing (the only realistic way would probably be through a drop, severe knock, serious mains power surge or mains power cut, incorrect shutdown procedure, or sudden disconnection of the power cable during use).
Back up regularly to an external storage device and do not ignore any warning signs. Also plug all computer equipment to the mains via a Surge Protector/Suppressor to prevent damage from power surges or fluctuations.
I hope this helps
Posted on Aug 27, 2011
  • 105 Answers
SOURCE: my screen says no bootable device-- insert boot
This sometimes shows up if the floppy drive is set as the first boot device in Bios, and the disk in the floppy drive is not bootable.
Have you attempted to boot to Safe Mode? To enter the Safe Mode menu, continually tap the F8 key just after powering on the computer.
If you're abe to boot to Safe Mode, try choosing the option "Last known good configuration" as the boot option.
If this doesn't work, try Safe Mode (with or without Networking)
We need to know if you can even boot before continuing. If you can't boot then you may need to do a Windows repair. Do you have the OS Disc?
Any doubts you can get in touch with a technician through
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Posted on Oct 05, 2011
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
It keeps tellin me no bootable device-- insert boot disk and press any key... i also dont have a disk drive all i have is a ubs flash drive spot
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 17, 2012 | Acer Aspire One D257 Netbook
My gateway says "Check cable connection!PXE-MOF: Exiting Intel PXE ROM. No bootable device--insert boot disk and press any key". What should I do?
Sounds like the hard drive isn't getting power,the data cable to the drive isn't connected,or the drive controller on the motherboard is toast(I'm a novice tinkerer,not an expert).
May 25, 2012 | Computers & Internet
HP Pavilion dv4-1548dx no bootable device-- insert boot disk and press any key help no disk
en mi laptop hp pavili
como hago si mi laptop hp paviliondv4 sale no bootable divice -- insert boot disk and press any key
Apr 23, 2012 | Computers & Internet
Keep getting black screen with error message no bootable device - insert boot disk and press any key ... computer will start in safe mode if i'm quick enough with the f1 key ... HELP
Hello good day, just remove your SATA cable from your hard disk if your using a SATA type HARD DISK, change with a new one, or try to pull it back and put it back tightly. It's just a loss contact situation.That's why you are receiving that message.
Mar 14, 2012 | eMachines T Computers & Internet
My screen says no bootable device-- insert boot disk and press any key
Sep 12, 2011 | Acer Aspire One Netbook
My daughter's ACER inspire one gives the following message and makes a beeping sound "Check Cable connection! PXE-MOF: Exiting Intel PXE Rom No bootable device---insert boot disk and press any key
There is a loose connection between the hard drive and motherboard of the computer, that's why you are getting that message. You most likely need to take it to a computer repair shop so they can fix it.
Mar 06, 2011 | Acer Aspire One PC Notebook
Well, my computer doesn't start up and the screen says "Media test failure, check cable", "No bootable device -- insert boot disk and press any key". I don't know what the cable is and...
The uProcessor can't find a bootable device and presumes your hard drive is no longer plugged in. Standard error message.
Check your BIOS for the hard drive listing. If it is listed there is no problem with the cables.
You will need your restore disc to boot from and repair your boot sector on the drive.
Feb 21, 2011 | Acer Computers & Internet
I get a black screen that say: Realtek PCI Express Gigabit Ethernet Controller Series v2.26 (090219) PXE-E61 media Test Failure check cable ****-MOF: Exiting PxE ROM No Bootable device- insert boot disk...
Apparently, the HDD has failed, that's why it doesn't find a bootable device and you can't restore te factory settings. You can try getting Hiren's Boot CD and use the testing tools to scan and fix the drive. Sometimes it just gets corrupted and returns to RAW format and just needs a format ( unfortunately you will lose all your data).
Nov 17, 2010 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
