Question about Admiral Dryers
Dryer only heats up sometimes - Admiral Dryers
  • 314 Answers
Rate these please
Instructions
  1. For Gas or Electric Dryers
    • 1 Check the setting on the dryer. It's a simple thing, but sometimes people forget that they turned down the dryer for a delicate load.
    • 2 Check the fuse box. Electric dryers require 240 vaults to run, which means they have a dual breaker switch. If one of the breakers clicks off, the dryer has enough power to run but not enough to produce heat. You may need to replace the fuse to prevent this from happening again.
    • 3 Check the outlet with a volt meter. As said earlier, electric dryers require 240 vaults to run. If there is not enough power to the outlet, but the fuses are fine, then there is a problem with the wires in your house. You will need to call an electrician.
    • 4 Check the thermal fuse. Depending on the type of dryer, this fuse will be located either in the front of back of your dryer. It is usually an inch long and mounted in white plastic. Test the fuse using a continuity meter. If the fuse has been blown, replace it.
    • 5 For electric dryers, locate the heating element on your dryer and test it for continuity using a continuity meter. If it is not working, you will need to replace it.
    Gas Dryers Only
    • 6 Check the igniter using an ohm meter. Disconnect the clear plastic connector (called a molex) that attaches the igniter to the burner circuit. Place the probes of the ohm meter on the contacts. It should be below 100 ohms of resistance. If it is above 100 ohms, replace the igniter.
    • 7 Using an ohm meter, test the continuity between the two contacts on the flame sensor. If there is no continuity, replace the flame sensor.
    • 8 If none of the above works and you notice that your dryer starts out hot but finishes cold and/or you hear a chattering sound when running the dryer, then your problem is likely with the coils. There is no test for the coils. Your only option is to replace them to determine if this is the cause.
Posted on Jan 15, 2013
Dryer heats sometimes and sometimes it doesn't
It could be a house electrical problem. Dryers need 240v to heat but can run with only 120v. Sometimes I seen were the power cord where it plugs into the house outlet is loose and will sometime heat and other times not.
Dec 27, 2014 | Maytag Dryers
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
H1 code for bottom dryer, sometimes won't heat
heatman101
Dec 30, 2010 | Maytag Neptune MCE8000AY Electric Dryer
My gas dryer only heats occasionaly - sometimes will work all day, sometimes only will heat one load and not heat the next. Any suggestions?
heatman101
Dec 18, 2010 | GE DPGT750GC Gas Dryer
My dryer only heats sometimes
heatman101
Dec 16, 2010 | Whirlpool Dryers
Model ALG643RBW Dryer heats sometime, APPEARS Flame Doesn't Always Ignite.
heatman101
Nov 22, 2010 | Amana ALG331RAW Gas Dryer
My GE dryer only heats up sometimes
heatman101
Nov 17, 2010 | GE Profile Harmony DPGT750EC Electric...
My dryer heats sometimes and sometimes it dont. Can anyone solve this.
heatman101
Oct 17, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer heats sometime other time wont heat
heatman101
Sep 26, 2010 | Maytag Dryers
What can make my dryer stop heating or to heat randomly?
heatman101
Jun 29, 2010 | Roper REX4634KQ Electric Dryer
Dryers Logo
300 people viewed this question
Top Admiral Dryers Experts
gbob59
Sal De
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
