Question about GE PTC22MFM Top Freezer Refrigerator
GE PTC22MFM How to remove back panel in freezer to located plugged drain
  • 51 Answers
SOURCE: removal of the back panel in the freezer compartment
try removing the side and bottom panels to remove the back panel
Posted on Jan 09, 2009
SOURCE: Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Posted on Jul 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: how do you remove the back panel of a PSC23NSTSS
Behind that cardboard there will be a drain exit that fill a pan that the fan blows over. But the correct way would be through the entrance and that is found inside the rear wall of freezer. Let me see if I can find some illustrations. Sea Breeze
Posted on Mar 27, 2010
  • 1891 Answers
SOURCE: I have ice on the
ther is not a diagram of what you want / and in the parts brake down it is a drawing and does not show the drain . but you will find it in the back of freezer under the evap coil . I use hot water and a turkey baster and clear the ice and force hot water down the drain . it shoud work . mm hope this helps .. feed back pls .. and if it keeps freezing you can add a drain heater . too correct problem .
Posted on Dec 11, 2010
SOURCE: How to remove front panel from ge ice maker model PSS26SGPASS
If you are talking about the ice/water dispenser palnel, on my PSF26NGPABB Arctica it just pulled off. there is double sided tape all the way around it and I used a thin, sharp knife to cut it as I pulled the panel off.
Posted on Dec 28, 2010
Ice at bottom of freezer
Hi Lee, you must remove the back panel of the freezer to access the drain.it has 4 screws holding it in place. Good luck
Nov 23, 2013 | GE GSS22JFMWW Side by Side Refrigerator
Pfss6pkw drain plugged
Unplug your refrigerator and remove items and shelves from the fresh food section. Not sure about what nutdriver so try a 1/4 inch nutdriver first and remove the screws holding panel number 98 in this photo HERE The beginning of the drain hole for the fresh food section is below the evaporator and in the center bottom of location number 96 in that same photo HERE For the freezer drain it will be behind panel 47 in this photo HERE You will only need the to remove the fresh food section panel ocation 98 and the freezer panel location 47 to clean these two drains. I have a video from You-Tube that shows where to clean out but his refrigerator had the drain visible without removel of these two panels. In most cases the drain cannot be seen without removal of the panels. I am here should you have questions Thanks Sea Breeze
May 16, 2013 | GE Profile Stainless Bottom-Freezer...
I have a GE PTC22MFMBLCC Top Freezer Refrigerator. I recently noted that the water line that dispenses the water to the ice tray has a drip leak. The drip starts at the back end of the tube. Now my...
the water valve is bad it is in the back under the frig. go to appliacepartszone.com put in the model # it is easy to repace just unplus the frig first
May 26, 2011 | GE PTC22MFM Top Freezer Refrigerator
PTC22MFM makes noise all day and there's water leakage in bottom fridge area. defrost all day, noise still there after a restart.
check the fan in the freezer and the fan for the condenser (behind unit in the bottom and clean the ciol for the condenser under unit
May 20, 2011 | GE PTC22MFM Top Freezer Refrigerator
Still having issues with my GE PTC22SBM freezer. Water is accumulating under the coils, freezing, then affecting the evap fan. I keep reading about checking the drain line, but besides the two holes in...
in back side under the frig there is a catch pan there you will see the tube ...blow it out and it shuld drian good after that. you may need to defrost fist
Mar 03, 2011 | GE PTC22MFM Top Freezer Refrigerator
I have a GE PTC22 fridge. I'm getting ice building in the freezer drain pan causing the evap fan to stop and things to get warm. I've cleared the 2 drains at the back left of the freezer, and is I see a...
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | GE PTC22MFM Top Freezer Refrigerator
PTC22MFM - need to unclog defrost drain?
Normally, this is a job for an appliance service company. However, turn off the refrigerator and remove the rear freezer panel. Once removed you should see a drain hole. Apparently, water does not drain properly. Use an extended coat hanger, etc. to place down into the drain hole with "up and down motions". Periodically, pour a small amount of water into the drain hole until it appears to be unclogged. Then follow up with some hot water and liquid bleach (perhaps a cup full). This should kill any algae, etc. and remove any other foreign objects from the drain line. If you pour too much liquid into the drain hole you may get an overflow at the bottom of the refrigerator (there is a small drain pan underneath the appliance that catches the water during the defrost cycle. Yet, the water collected in the drain pan, during the defrost cycle, typically evaporates and you should never have to regularly empty the drain pan. Good luck!
Feb 20, 2010 | GE Refrigerators
Replacing Light bulb in a Frige
Open refrig door, look at control panel, on each end of control panel there should be philip screws holding panel, remove screws, drop panel down slowly, replace light. Install in reverse order.
Oct 16, 2009 | GE PTC22MFM Top Freezer Refrigerator
Leaking water from freezer side-by-side GE refrigerator
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside panel in the freezer and unp,ug the drain. Once you remove the rear panel, you should see a collestion of ice under the evaporator coil. Locate the drain hole and clear the ice. Flush the drain hole out with hot water to make sure it will drain. You might have to run a wire through the drain or you can flush water through it with a baesting serienge.
I hope this helsp you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
GE side by side refrigerator-1994
Check your drain pan for water.If you see none than you have a clogged drain line in the freezer.Remove the back wall lower screws and any screws that will prevent you from getting the back freezer panel off,NOTE : this is in the freezer located on the back wall. You will see the drain behind this panel , if its clogged ,un clog it.
Jul 23, 2008 | GE Profile Harmony DPGT750EC Electric...
GE PTC22MFM Top Freezer Refrigerator Logo
44 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
