A
Anonymous Posted on Jan 15, 2013
Why does ativa vortex hs c680 power light not working?
1 Related Answer
Anonymous
  • Posted on Jul 25, 2011
SOURCE: I have a HS C680 Shedder. I put a full envelope
I have same problem, did you ever get yours to work and how?
I have an Ativa Vortex HS C680 shredder. It jammed with 4 sheets of paper and when put in reverse it made some unusual sounds so I turned it off.
Press both RELEASE buttons on either end of the module at the same time and remove it. Remove the panel and carefully pull out the jammed paper. Locate and clear away any small bits of paper that remain. Push the module back on and snap it into place.
2answers
Ativa Vortex hs c680 Manual
there's are website that I know all heavy equipment repair issues servicing, loading, wiring, engine problems everything is covered here its a must try for those who aren't fully equipped with tools or knowledge
Ativa Vortex HS 2000 shredder manual
I take help from online websites
that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is
up to us.. U can also get free manuals
1helpful
Ativa HS1000 (Vortex) - the red light indicating that the shredder tray is full is on, however it's empty. There is clearly a piece of paper stuck in the shredder, but it's not letting me reverse...
Disconnect from the electricity. Remove the bin. Flip the shredder upside down. Brush the blades to loosen/remove any cut paper. Then using a thin plier remove any jammed pieces of paper.
Red light is on. Ativa Vortex HS1000, looks like a thermometer will not do anything at all. what is going on?
That thermometer light is only on when the unit is overheating. If it is not doing anything, that is a good thing!
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
The Denon DN-C680 gives ERROR 105 on the display. Why?
2answers
Shredder won't turn on
ok " if the ready light did not come on it's telling you that there is no power sound like the plug in transformer is no good .
you can check that transformer , with a multimeter, see if you have the right voltage.
k24674
ADMIN Andrew
ADMIN Andrew
