Question about Cub Cadet Garden
Won't turn over
Battery charged but won't turn over
    Sergeant:
  • 322 Answers
You probably have a bad starter solenoid. You can check it by jumping across the two terminals. If it cranks over then it is bad, if it doesn't then you have another problem and need to check the battery cable connections and/or starter, but I would look at the solenoid first
Posted on Jan 16, 2013
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
I just bought the eclipse cld and it won't turn on after charging for hours
Sep 30, 2012 | Eclipse Audio Players & Recorders
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
My phone won't turn on
Sometimes a phone won't turn on until you have enough charge in the battery to enable this. What I mean is if the battery is so flat, it might take ten or so minutes to start to so a charging state.
Sep 06, 2012 | LG ALLTEL AX275 Cellular Phone
My Computer Kepps Turning off!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 15, 2012 | ASUS Computers & Internet
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Turns off as soon as the power outlet swtich is turned off
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time or when the mains power is removed. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 15, 2011 | Lenovo ThinkPad SL500 Notebook
Garden Logo
138 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
