Question about Jabra BT2050 Bluetooth Headset
When is my jabra type ote3 fully charged?
I haven't used it in years. It's been on the charger overnight, & it's still giving me a slow blink on the white led. . .
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
  • 4 Answers
SOURCE: Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Posted on Dec 08, 2009
  • 638 Answers
SOURCE: Jabra OTE3 won't pair with Verzon LG phone. How do
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
  • 16 Answers
SOURCE: jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Jan 07, 2010
  • 638 Answers
SOURCE: How do you put a Jabra GNM-OTE3 in discovery mode?
password is 0000
Posted on Jan 08, 2010
Left key in ignition overnight, had to jump start bike. now the main fuse keeps blowing
You haven't said what model or year of kawasaki.
Some newer bikes aren't supposed to be jump started. Take the battery off the bike, replace the fuse, charge the battery on a proper charger overnight (as opposed to a battery conditioner like optimate). It should now start fine and not blow the fuse.
If that doesn't sort it, the dealer will need to reset something.
Jul 25, 2011 | kawasaki Vulcan 500 Ltd EN 500 C...
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I'm trying to pair my Jabra GNM-OTE3 with my laptop. Devices not finding it. Can I get a driver?
Hello sir, honor to make you know that GNM-OTE3 is not a valid model of jabra products. try to identifie your product first you can post a photo for it and I can help you in the future. Bye
Oct 29, 2010 | Sony Computers & Internet
It did not charge
The you have either not inserted the charging plug fully, the charging socket is faulty, the charger is not working, or the battery has failed.
I'll assume that you're familiar enough with your headset not to have done the first option. The charging socket is probably ok if there's no obvious visible damage and it's likely that the charger is working too as they're so reliable, but you can always eliminate it as a possibility by borrowing another charger or testing the socket output against the figures printed on the charger.
But by far the most likely culprit is the built-in rechargeable battery. It's not designed to be replaceable as the complete headset is only expected to last two years, but Jabra do have a one year warranty on it: if it fails they just exchange the complete headset for a new one (or the charger if that proves faulty). Your unit can't be very old as the model is a fairly recent one, so you should first try for a repair, refund or replacement (your choice) from the retailer (a legal right under the Sale of Goods Act if you're in the UK) and then contact Jabra directly if either the retailer won't help or if Jabra has told them to refer all repair claims to them.
You'll find a link to the warranty terms here.
May 07, 2010 | Jabra BT800 Consumer Headset
Jabra BT150
The first dude is an idiot! The battery is toast go buy a headset that isn't as old as this Jabra! I also have the issue & no didn't plug it in wrong...it only goes one way! Mine sat for a few years unused & now will not charge...You can get newer headsets pretty cheap! Look around!
Apr 29, 2009 | Jabra BT150 Wireless Headset
Aug 22, 2008 | Jabra JX10 Bluetooth Headset Headset
Jabra BT2050 Bluetooth Headset  Logo
410 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
