Question about Garden
How to replace transmission seal on john deere gt 245 mower
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Posted on Jul 25, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
SOURCE: LA150 john deere riding mower transmission slips
this transmission is a sealed unit, no way to add fluid or change filter.
Posted on Aug 12, 2010
Why does my john deere gt 245 die when I engage the pro or release the brake
Sounds like a safety switch, you just have to hunt it down, possibly in the bottom of the seat
Feb 13, 2015 | John Deere Garden
John deere gt 245 shoots fire out of the exaust
Souinds like badly burnt or stuck open exhaust valve(s)
Oct 05, 2014 | Garden
John deere gt 245 backfires
Sounds like exhaust valve stuck open somewhat if it backfire through the exhaust, intake if back through the induction system. It could also be cross fire between plug wires or ignition timing not correct.
Why would a john deere gt 245 mower be Skipping,
Possibly burnt valve(s) or less likely timing has slipped or ignition cross fire between high tension wires.
Why does it idle up & down constantly
which v-twin ???
Kawasaki or Briggs or Kohler
but I'd suspect a dirty carb just by your question
Aug 30, 2014 | John Deere Garden
I just got this broke down John Deere 245 with the 14 hp Kawasaki. Everything works but one major problem it doesn't move. When I move the transmission to forward or reverse I have no movement. I have...
well if the drive belt is working, that is it turns the large pulley on top of the transmission, then most likely you have a bad transmission. the last owner found out that it will cost more to get another transmission than the tractor is worth. there is a small stamping along the bottom center of the transmission, will tell you the make and model and you can start searching for a NOS one on ebay or a used one at a lawn mower junkyard.
Nov 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Where is the chassis serial number located on my John Deere GT 245
it is usually on rear of tractor toe frame,side of frame near engine or under seat should start with moo...... white sticker
Jul 17, 2010 | John Deere Garden
John deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 10, 2009 | John Deere Tractor Side Screen...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
