Question about Abit SG-80 Motherboard
Got power, but no booting activity
Hi, I just bought a brand new SG-80, placed it in my cabinet and plugged everything in (CD, HDD, Floppy, front pannel devices, etc.), but when I tried to boot, to install WinXP SP2, I got no boot activity at all. FP LEDs display constant HDD act., but no PWR act., LED works OK (already checked it for propper functioning by switching places with both LEDs). Floppy's LED stays on, & CD doesn'st work if it's plugged in. Already read other guys' problems, but all of them actually got their MB to work at the begining; mine doesn't work at all. The CPU's fan bends the MB but not as in the picture displayed in the other issue. Haven't tried using the eraser, but figured out something better would come up. Thank you everybody.
  • Luis Hernandez
    Luis Hernandez Jul 10, 2007
    OK,thanks, but I don´t have any RAM Memory, so do I NEED one?
    President:
  • 2,961 Answers
Assuming you have compatable memory fitted to the mobo; if you cannot get as far as the power on self test (P.O.S.T) or into the bios to set it up, remove all components you have fitted apart from the memory and the hard drive and a graphics card if not on board graphics and see if you can get as far as the post screen. If nothing appears and you just get a flashing cursor, then either the bios chip is faulty, or you have possibly stressed the board when fitting components and accidently broke a soldered contact. If you do get the post try putting back one peice of hardware at a time until you come across the problem part.
Posted on Jul 10, 2007
  • andrew pester
    andrew pester Jul 10, 2007
    Yes the system will not boot without memory, you have to fit a memory stick, otherwise nothing will happen.
Stuck at Motherboard splash screen
your stuck at the boot from DVD, you must boot form C to finish installation.
Jul 27, 2014 | EliteGroup P4M800-M7 Motherboard
My ABIT sg-72 motherboard boot attempt from HDD says "NTLDR is missing". The only Enabled boot device is HDD. If I change boot device in setup to CD (Windows XP distr disk), that boots up and...
first check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppy drives ,and no removable usb drives plugged in to the usb ports
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
don
Feb 13, 2011 | Abit SG-72 Motherboard
I have an optiplex gx150 pIII, with a floppy drive. I downloaded the set up floppy so I could do a new install. after running the floppy disk, the messages says hit enter to continue. I place the xp sp2...
You don't need the install floppy... hit the F12 key when booting and you will get a boot order selection and tell it to boot to the CD. If it still doesn't see the HDD then you are most likely having a disk read problem with your hard drive. If that is the case you should boot into the system BIOS and see if the HDD is recognized there.
Apr 01, 2010 | Dell OptiPlex GX150 PC Desktop
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
Abit sg-80 1.0 bios driver
go web site dl bios make floppy show su on site how to do it or maby flash tool tanks nick
Oct 10, 2008 | Abit SG-80 Motherboard
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Help pc problems???
CHANGE THE POWER SUPPLAY.. BUT FIRTH..
1-UNPLUG HD AND TEST WITH FLOPPY OR CD BOOT DISK
2-UNPLUG YOUR MEDIA ROOM LIKE CD OR DVD AND TEST ONLY WITH FLOPPY BOOT DISK
3-UNPLUG VIDEO CARD AND ALL CARD ON YOUR MOTHERBOARD.. TEST ONLY WITH THE FLOPPY DISK AND ONBOARD VGA.. OR GOOD TESTED VGA CARD.
EXCUSE MY BAD ENGLISH.
CO3OV
CUBA
VICTORES45@YAHOO.ES
Oct 14, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
No Booting to BIOS, Monitor just stays on Save
If there are no beeps at all on boot up it's a memory timing problem, Go into bios in standard bios settings menu and disable 'Halt On All Errors' if it isnt already, this may show up the problem in the initial power on self test.
Oct 26, 2006 | Abit SG-80 Motherboard
Abit SG-80 Motherboard Logo
149 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
