Question about Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET
Need manual for utilitech 43467
I need the owners manual for the utilitech shallow well pump #0043467. I need to know how to adjust the pressure.
    Top Expert:
  • 35,684 Answers
You might be able to obtain this directly from the supplier
Posted on Jan 15, 2013
Pump shuts off at 20psi
you need a new pressure switch or adjust the old one for a higher limit ,
Dec 30, 2015 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a 1/2 horsepower Utilitech pump hooked to a 36 gallon utilitech tank and need to know the cut in PSI
For normal house service cut-in is usually 20 psi, cut-out 40 psi. The pressure switch can usually be adjusted to 50 psi. For any more check the pump specs. Usually you can google that.
Aug 18, 2015 | Plumbing
Why would my 1 hp pump only maintain 45 psi running 1 garden hose?
Without knowing all your variables with well it is hard to say. Bladder tank needs to have 30 psi with no water pressure. It is possible that the screen down the well is restricted and you are only getting that much water. Or you may have clogged impeller in pump.
Sep 04, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Once the water is shut off the pump keeps running
the pump is controlled by the storage tanks pressure switch , if it continues to run well after the pressure tank has refilled with water , either the switches manual override has been activated (lever) or its defective or blocked off with mud
Jun 27, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Apr 21, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
I have a utilitech jet pump can only set pressure to 20-40 would like to set to at least 30-50 but cannot .The pump is less than 6 months old .any ideas other than i bought the wrong brand
Sorry Richard,
Sounds like you are correct, you bought the wrong type of pump...if your looking for pressure/output you might consider purchasing a "sprinkler pump"...they will go past 70psi and more
Please take time to rate me
Bud
Mar 31, 2013 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground lines....
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Bud
Oct 21, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Need to know which way to turn the two nuts that adjust pressure on a flotec shallow well pump .and pressure tank combo.
If you can post the model of your equipment I can at least locate the owners manual which should have your answer.
Dec 17, 2009 | Home
Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET Logo
615 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
