Question about Dryers
I want wiring of timer.
I want know the color code of electric wires on timer.a mouse has cut all wires MODEL,DNLR223EGWW TIMER MODEL,M460_G
  • 314 Answers
What type of dryer are you talking about please rate these
Posted on Jan 15, 2013
SOURCE: wiring diagram
Had a three prong plug and now the new apt calls for a 4 prong plug...which I have but no diagram to show which color goes where.
Posted on Sep 16, 2008
hunter19_46m
  • 7482 Answers
SOURCE: Hello, My GE Dryer, Model M460-G timer won't shut off
Sounds like you have a faulty timer switch, check with your local supply house and get the same type of switch.
When you go to replace the timer switch, unplug the dryer, then remove one wire at a time. This will prevent wiring mix-ups.
Good luck,
I hope this helps
Posted on Oct 11, 2009
Testimonial: "Thanks for your help, I greatly appreciate it.We live in the middle of no where so I will have to order it online once I figure out the correct part #"
hiltonjug
  • 612 Answers
SOURCE: need color code wire diagram for control wires on
This info should be located behind the control panel of your dryer. If not, someone must have removed, try asking again if it's gone.
Posted on Oct 19, 2009
wfservices
  • 260 Answers
SOURCE: looking for dryer diagram
There should be a schematic on the inside of the back cover, sometimes it is located in the top control panel somewhere(timer panel)
Posted on Feb 23, 2010
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Bought a new dryer timer. The recommended part for Kenmore dryer model 110.97281100 is WP3398190. The old timer model is M460-G and 3391658. Things do not line up exactly.
From your description, it seems you do not have an exact replacement. See what www.searspartsdirect.com has to say. Don't be surprised if you get several different answers.
Nov 07, 2016 | Kenmore Dryers
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
Need to know which color wire goes to which connector on the timer. frigidaire wiring diagrams
Hi garyab9ss, I appreciate your post!
It appears your inquiry is listed under Frigidaire Electric dryer and you need the wiring diagram. May I have the model number please? You can typically locate the serial tag (which lists your model number) on the upper front, as you open the door or on the right/left edge on the inside of the door. Also, please provide me the timer part number that you have in hand. With this information I can deliver the correct material to you. Thank you! - Z
Jul 28, 2014 | Frigidaire Electric Dryer
M460-g timer wiring diagram
You will never get a diagram for that. The M460 was used in thousands of machines, did you pull the bone-headed move of removing the timer leads without marking them? Post the actual model number of the machine and I can find the diagram for that model and work off of that... Help Me Find My Model Number RepairClinic com
Aug 18, 2012 | Maytag Dryers
Model 57194 wiring
Re-post question with clear description of timer, and brand of timer, and what timer is controlling.
Jun 22, 2012 | Hardware & Accessories
How to connect a light timer switch
Timer is not identified.
Add a comment and describe timer, and say if timer has wires, then describe color of wires on timer.
If you have box type timer, then add comment with model number that appears on door.
1) There are two types of in-wall timers: battery-operated timers and electric-powered timers are wired differently.
Open following link for typical single-pole electric-power timer wiring.
http://waterheatertimer.org/Programmable.html#wire
2) There are two more variations on in-wall timers.
Battery-operated timers can be used to replace single-pole and 3-way switches.
Open following link to see timers that work for 3-way.
The wiring is more complicated for 3-way timers since each model wires differently
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Oct 04, 2011 | Electrical Supplies
Good luck,
I hope this helps
Oct 11, 2009 | GE Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
