Question about Akai LCT3201AD 32 in. LCD Television
Won't turn on
Must push on/off switch repeatedly
  • Akai Master
  • 933 Answers
Ok, so pushing the button repeatedly turns the set on?
Posted on Jan 15, 2013
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
CD player won't switch to next cd and keep playing
Look for a button that says repeat ...push if to turn it off..if it has schuffle , try hitting that.
Dec 24, 2012 | Denon AVR-1803 Receiver
I was refering my laptop an when I shut off I turn on an it starts like to turn on that processes but that's it won't do noting else its a toshiba satellite
Your statement is a bit confusing. Try thi,s unplug AC, remove battery, replace battery, plug into AC outlet push on/off button start normally. If that fails repeat and at boot repeatedly tapping F-12 to enter restore/recovery.
Nov 08, 2012 | Computers & Internet
Escalade 03 courticy lights won't come on when door is opened
Next to the head light switch you should have a roll dial switch and a round over-ride button push this once and overhead courtesy light goes on/off push twice and it over-rides headlights sensor to turn on/off
Sep 19, 2012 | 2004 Chevrolet Tahoe
I have a Magnavox 15' HDTV monitor and it won't turn on, when I push the on switch on it turns green and a split second later it turns yellow. whats wrong?
This is typical when there is no communication with video card. Test on another PC. Re-seat video card on PC. Use VGA cable instead of HDMI or DVI. Make sure monitor is correct mode. Again VGA, DVI, or HDMI, depending on cable used.
Aug 27, 2012 | Philips Magnavox Computers & Internet
91 dodge Dakota headlights and incab lights won't turn off
Replace the switch
If you have other problems ,I have
a 1992 service manual & wiring diagrams
Turn off or time out?
Jun 08, 2012 | 1991 Dodge Dakota
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
'91 LS400, trunk will not open. key will not turn, electric latch switch clicks but won't open. valet lock in open position. Tried 1) disconnect battery, reconnect battery, use switch, push down on...
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
May 26, 2011 | 1991 Lexus LS 400
Akai LCT3201AD 32 in. LCD Television Logo
19 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
