Need the driver download for the Lexar JumpDrive S50 USB Flash Drive. Purchased this item, and Windows 7 cannot detect it. Been searching for the driver online. No success.
SOURCE: When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY
Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
SOURCE: Please show me step by step on using the Lexar 2GB
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
SOURCE: How to recover data from a seemingly dead/non-functional USB flash drive
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
SOURCE: Have windows xp I need a driver for a lexar 2.0 4GB
No driver needed, when plugged in it should just appear in My Computer. If it doesn't that means the memory stick is dead, junk it.
SOURCE: Lexar JumpDrive S70 - USB Flash Drive - 8 GB disconnect
this could a problem with an unstable driver you might have to unistall the driver restart your computer then reinstall the driver you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts you will need to download one try one of these http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html Install a USB 2.0 host controller driver http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
if you motherboard came with a disk the drivers could be on it
otherwise you might need to download them
or a bad dusty or loose usb lead connection
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
hope this helps
Perhaps I could add more to my question. I realize the Lexar Jumdrive S50 is plug and play, but for some reason it can not be found on my system. (Windows 7) I can see it in Add devices, and when I check for driver updates, or troubleshoot, Windows detects my driver is upto date, and no other issues. But I can not locate the stick through My Computer or any other means. Can someone perhaps give me a few more ideas...?Thanks
