Question about Audiovox Prestige APS997C Alarm/Remote Start with Doorlock Interface
Audiovox APS997C is making a constant clicking noise, the led is flashing fast and constant, the remote says the alarm is on and will not turn off, and it is running down my battery.
  • 108 Answers
SOURCE: audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Posted on Sep 28, 2008
budmrtn
  • 11361 Answers
SOURCE: Tv power comes on but no picture th name Audiovox
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 01, 2009
  • 19 Answers
SOURCE: no remote for alarm
until you get a working remote, you should unplug that alarm
Posted on Jul 29, 2010
kayzack519
  • 226 Answers
SOURCE: i have a 2000 toyota
sounds like the "brain" for the alarm system is on its way out
Posted on May 25, 2011
gopakumarg43
  • 74383 Answers
SOURCE: tv wont turn but makes clicking noise
There is short circuited component/s at its main board. Power supply regulator section is working fine. You have to check for fault at its horizontal scan output section circuit. Check the horizontal scan output transistor, and check. Contact any service technician. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Dec 30, 2013
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
How do unlock my sentry electonic safe?
Hello, If you don't have the combination you will have to write sentry cust service with the model and serial number to get the combination. Here is their number you can call: (800) 828-1438
Jun 01, 2014 | Audiovox APS20B Prestige Programmable...
I have a APS997C installed on a 2008 F-250 diesel. When remote starting it all the lights on the dash light up everything turns on but won't remote start. My remoted says inhibit. I have check the brake...
Does the vehicle have a hood pin installed ? Chances are the pin rusted out and it thinks the hood is open, that would make it not remote start.
Feb 22, 2014 | Prestige Remote Start
Remote start starts car and dies off after few seconds
try having the cpu reset using a code reader as you may have two systems operating in conflict that is causing the problem.
Jul 29, 2013 | Audiovox Prestige APS997C Alarm/Remote...
Will this alarm work in my 2004 yukon
Most likely yes, but you may need a professional install, there are many issues involved to make it work properly, safely and with a single remote per user.
Oct 14, 2010 | Car XRO9100 900 MHz Remote Start / Alarm...
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
My Viper 5701 has been flawless but now on locking/unlocking the car no longer "chirps." Everything else still works perfectly such as the flashing lights. The remote also has changed its noise from the...
Check to make sure that the valet is not engaged. The alarm will notify you by having a constant lit light. If the light flashes like it should open a door and check to see that the light blink on and off as if the alarm were triggered. If this happens the your problem is with the siren, just have it replaced.
Jul 27, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Alarm stopped working
sounds like the system is in valet mode.
locate a switch under dash if a toggle switch is found then turn on key and flip switch. turn key off if led is off try alarm.
If a push button switch is found then turn ignition on and press the switch for 10 seconds, then turn key off iff led is off try alarm.
Sep 22, 2009 | Vehicle Parts & Accessories
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
Audiovox Prestige APS997C Alarm/Remote Start with Doorlock Interface Logo
44 people viewed this question
Top Audiovox Electronics - Others Experts
Lawrence Oravetz
Bill Boyd
Are you an Audiovox Electronics - Other Expert? Answer questions, earn points and help others
