Question about Gateway Nv57h96u 15.6 Laptop Intel Core I32350m Cpu 4gb Memory 320gb H
Windows will not load now... it just keeps looping back to when its about to load with the windows logo, then the screen blinks blue with some text in the top right corner..but it blinks so fast i cant read what it says, like a half of second.
  • Gateway Master
  • 17,155 Answers
Try booting to safe mode by tapping the F8 key before the windows logo. if it boots let me know
Posted on Jan 16, 2013
4 Suggested Answers
shibuda
  • 1812 Answers
SOURCE: Hi i have a gateway
The way to restore Gateways is to hold down the ALT Key andrepeatedly hitting f10 then it should bring you to a boot sequence screen thenchoose the HDD and then hold down ALT and repeatedly hit f10 again that shouldprompt the restore feature for gateway. If that doesn't work,the only way to doit is to boot into windows and run the Recovery program.
ALL DATA WILL BE ERASEDON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THEPOWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURINGTHIS PROCESS.
Hope this helps,
Posted on Feb 26, 2011
  • 81 Answers
SOURCE: windows does not load after gateway logo
This sounds like you have no operating system on your laptop. I bet someway, just as I did before, you have lost your operating system, and it needs to be reinstalled on your computer.
Posted on May 30, 2008
  • 38 Answers
SOURCE: TOP HALF OF SCREEN WORKS,BOTTOM
If the external monitor works - The problem is in the screen or cabling of your Laptop
--> Needs to replace.
Minor change but anyway:
If the extenal monitor has same challenges the problem is in laptops motherboard and actually in display card which normally is integrated
Posted on Jan 06, 2011
Need help - black screen on Samsung 700A3D
Looks like the boot manager file could be damaged or a driver is missing. Use your windows disk to boot from and choose the repair option.
Aug 31, 2016 | Samsung Computers & Internet
My dell inspiron 1454 keeps looping on the boot up screen, then just goes back to the windows has filed to start screen..
Hi Charlotte,
The video doesn't show what you describe. The video shows that Windows is loading. Try booting in safe mode. Here's how:
Power up the machine. When the Dell logo appears, start tapping the F8 key until the Advanced Boot Options menu appears amd choose "Windows Safe Mode." Once windows starts, backup your data just in case. Then try to determine what it was you did last that may have caused the problem. Then try to start normally.
Hope this helps
Randy
Nov 02, 2012 | Computers & Internet
Compaq nc8230 stuck in startup loop after system restore to earlier date
on startup time press F8 for no of times.From option click repair and continue with instruction,When asking for password ,change user name and click enter
Mar 13, 2012 | HP Compaq nc8230 Notebook
When I turn my Toshiba A45-S151 laptop on, I first get the screen that shows the Toshiba logo and has the four icons under the logo. Usually the next screen is black, has a cursor in the top left corner,...
That blinking cursor is the way in which the BIOS is telling you that Windows is not loading because its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 18, 2010 | Toshiba Satellite A45-S151 Notebook
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
Can not find restore disk
Did this problem just happen out of the blue? Were you using it and suddenly the PC just up and went belly-up? If so, it sounds like you may have bigger problems than merely a Windows problem. If you don't even see the eMachines logo at bootup before the Windows logo, then something more serious, like a motherboard issue, is your problem. Post back with more specifics, but if you don't see anything at all at booting, like any text or logo or anything, then at the very least the integrated ATI video isn't working. The solution then is either get it fixed with a new motherboard or buy a new one. As this particular model is >1 year old, it won't be under warranty, hence more expensive than it's worth.
On the other hand, did you make any hardware changes that you didn't mention? If so, post back with details.
Jan 04, 2009 | E-Machines T5082 PC Desktop
My compaq Presario V6000 will not start windows, it continously loops to an options screen with the following start options; Safe mode, safe made with networking, Safe mode prompt command,Windows last...
what you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
Nov 13, 2008 | Compaq Computers & Internet
Xp caught in loop when started
the Windows Operating system is corrupted.
what operating system are you running??
Windows VISTA or XP??
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Gateway Nv57h96u 15.6 Laptop Intel Core I32350m Cpu 4gb Memory 320gb H Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
