Question about Frymaster Dean H17-SC Deep Fryer
Pilot light I have a Frymaster J1C deep fryer and the pilot light goes out when the main burner reaches tem and shuts off.
    Scholar:
  • 127 Answers
Are you sure that the fryer is not shutting off on high limit? The high limit switch will shut off the main burner and pilot as well. The high limit will trip if the thermostat is defective or if it is out of calibration and does not shut off the main burner when the set point is reached within normal operating limits. In either case the oil gets too hot, ~425F. Check the oill temperature when it shuts off. The high limit may also defective. Check for continuity between the high limit leads immediately after it shuts off. If the leads show no continuity at normal oil temperatures, the high limit is defective. The high limit will automatically reset when the oil cools down, so it must be checked immediately after shutdown.
There are other possibilities such as a weak pilot, weak thermopile, loose or damaged wiring or connectors, ect., but in these cases the fryer will often go out randomly, not just when the main burner shuts off.
Posted on Jul 07, 2009
    Problem Solver:
  • 19 Answers
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Posted on Feb 05, 2009
Pilot light will no ignite when I follow steps on door. What may be the problem ?
Defective thermocouple. If it pilot light goes out after letting go of the button, the thermocouple is not producing enough voltage to keep gas going to the pilot light. Heat on the thermocouple produces it own power. It is a safety feature to prevent the main gas from operating when there is no pilot light.
Aug 29, 2015 | Frymaster Dean SR142GP001 Deep Fryer
Our Imperia fryer pilot lights shuts of once the temp reaches 200 degrees
If both the main burner and pilot shut down at 200F, the high limit is bad. If only the main burners shut down, the thermostat is bad.
Jul 17, 2014 | Imperial Kitchen Appliances - Others
My pilot light will not stay lit. I have replaced the thermocouple and still will not stay lit. Can the valve be bad?
Make sure the thermocouple is deeper into the flame of the pilot light. It needs to reach a high enough temperature to produce a high enough voltage to keep the pilot light lit all the time. I do not think that the main gas valve is bad at all.
Nov 25, 2010 | Frymaster Dean SR42G Deep Fryer
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
Shallow fryer pilot light goes out
Call fafctory service dept 800-637-9188 ext 22
May 27, 2009 | Comstock-Castle 14HF Deep Fryer
Imperial deep fryer IFS40 pilot lights, turn on gas valve main burners come on run for awhile then everything shuts down main and pilot. You can disconnect the thermostat and the same thing happens, main...
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Feb 18, 2009 | Imperial IFS40 Deep Fryer
SR24
It could be a faulty high limit, you can also check the high limit probe to insure it is mounted securely against the through tube wall in the grease. Also check the burner, there are baffles that run through it and when they get old the flames don't move though the burner correctly and will cause the high limit to trip prematurely
Nov 09, 2008 | Frymaster Dean 2424G Deep Fryer
Dean deep fryer
need to change from natural to propain sr42 g
Oct 08, 2007 | Frymaster Dean SR42G Deep Fryer
Gf 40 frymaster fryer
Hi, I am suposing that this fryer has worked good in this location before. If not, check to make sure it is set up right for your gas supply. (LP-Nat) There is something wrong with the gas - air flow in your unit. Look for obvious things first like exhaust being blocked, Flame dancing out side of fire area, Pilot too small, Build up of debris in fire box. The pilot should be able to be adjusted at the gas valve if it is too small. I believe you problem could be taken care of best with a good cleaning of the burner, fire box and pilot assemble. Make sure that all burner holes are clean especially around the pilot light. Check for oily debris inside the fire box to make sure its not leaking into the fire area. If you are unable to do this yourself, contact some one either in the restaurant equipment service business or heating and air conditioning business. Hope I have helped you. kstfas NOTE: If this answer does not rate at least 4 marks, (almost there) please do not rate. Thank You.
Sep 26, 2007 | Frymaster Dean GF40 Deep Fryer
Frymaster Dean H17-SC Deep Fryer Logo
309 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
