Question about Nortel Meridian M7208 Corded Phone
The handset does not work on the Nortel M7208
I have a client that has a Nortel M7208. She had forward the phone line to another extension. When she was doens she released the forward. now the handset does not work. To get the phone to work we had to move the handset to the headset port on the back of the phone. To troubleshoot we replaced the ohone with a second known good phone and it did the same thing. I ahve been unable to find a way yo get it to work. Any help would be greatly apprecaited
3 Suggested Answers
SOURCE: call forwarding on t7316 nortel system
turn on feature 84.... turn off feature # 84
Posted on Jun 25, 2009
SOURCE: changing name in nortel T7316E handset
We would like to change the name displays on our phones
Posted on Oct 22, 2009
HOW CAN I TURN UP THE VOLUME ON HANDSET. VOLUME IS SO LOW CALLERS CAN NO HEAR ME
There is no outgoing (microphone) volume control, if it is only your set try the handset from different extension. The microphone element may have been damaged (especially if dropped) and have to be replaced. Replacement handsets are not hard to find. If everyone on your system claims that callers cannot hear them, there are some settings on the central switch (KSU) which might help, but only after ruling out a problem on your particular set.
Jun 16, 2014 | Nortel Meridian M7208 Corded Phone
Nortel M7208 will not dial
A button may be stuck on the dial pad. Check all buttons to ensure they are free and none of them are stuck.
Feb 11, 2014 | Nortel Lands Phones
How do i forward calls to an outside line on Nortel M7324
You can forward an extension that is not used at all, and has the lines assigned to ring that you want to forward to an outside number. In programming have the extensions set to forward on busy to the external number using 9+ the number desired. When you leave for the afternoon, take the handset off the phone, and replace it when you return. NOTE THIS EXTENSION MUST NOT BE USED BY ANYONE -- IF THIS EXTENSION IS BEING USED AND A LINE RINGS IN IT WILL BE FORWARDED OUT.
Mar 19, 2013 | NorStar M7324 Telephone
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
How to make phone ring for two incoming lines
This is tech side programming known as Configuration, clients usually call in a tech/vendor for this.
You need to find out the password and know how to navigate the system programming, do F**266344 and enter the password.
Navigate to Sets, add line in question , assign ring type.
Dec 10, 2012 | Nortel Lands Phones
I am trying to figure what my extension is? I have an M7208 Nortel
Do a button inquiry to find your prime line(intercom number). Press feature *0 then the button you want to identify. Your prime line will be either the bottom programmable button or the next one up.
The button defintion will appear in the LCD screen for each button inquiry you do.
Dec 22, 2010 | Nortel Meridian M7208 Corded Phone
Getting the M7208 to work
Nortel M7000 series are proprietary sets which require a nortel MICS, CICS, or an older 8x24, 6x16, or 3x08 in order to work. If you have the system, it maybe that the jack isn't activated with a system port.
Nov 24, 2009 | Nortel Meridian M7208 Corded Phone
Unable to transfer calls to a certain internal extension using a M7310 Nortel Corded phone
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
Sep 28, 2009 | Nortel Meridian M7208 Corded Phone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Jul 02, 2008 | Nortel Meridian M7208 Corded Phone
Nortel Meridian M7208 Corded Phone Logo
55 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
