Question about Kenmore Dryers
Stops and all the lights come on
The machine turns in one direction once or twice then stops and all the lights start flashing.
  • 314 Answers
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Posted on Jan 15, 2013
Turn signals work inconsistently. fuse and bulbs fine
start off fine and then just once or twice and then not at all. don't know what will happen. Inconsistent.
Jul 02, 2014 | 1998 Chevrolet S-10 Pickup
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
2000 stratus beeps twice, flashes twice, repeats untill stopped, but it drives
This is usually a good situation to bring to alarm shop and have them take it out and see if you can just keep the remote start or it might need a new brain on the alarm system
Dec 10, 2013 | 2002 Dodge Ram 3500 Truck
PT61LCZ70K panasonic tv won't turn on, flashes green light for a couple of minutes then flashes red twice then stops and flashes red twice again. TV Made in Feb 08 lamp shouldn't be gone yet. Manual says...
have a tech clean inside cabinet and replace bulb , should be under warrantee if under 5 years old just had mine done free of charge from panasonic call 1 888 843 9788 they will direct you to a dealer. hope this helps
Oct 01, 2010 | Panasonic PT-61LCZ70 Television
Steam function on the BES400 just stopped working! its been working fine for about 6 months & now the light just continues to blink, no pressure, no steam!
Hi. Did yo fix this? I seem to have the same problem - just started happening today - machine has been working fine for 18 months.
Thanks
Mar 13, 2010 | Breville BES400 Espresso Machine
My 1997 Dodge mini van will not start. When I do
The flashing check engine light would mean that the engine is misfiring, If you have a scanner, use it on the diagnostic port of the engine to check for the error code to get which cylinder is misfiring and if there are other errors that needs to be checked.
Jan 19, 2010 | 1997 Dodge Caravan
The cleaning button keeps flashing after cleaning. I have cleaned this with water & vinegar several times, but can only make one or two pots of coffee before the cleaning button begins to flash again....
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Oct 10, 2009 | Cuisinart DCC-1200 Coffee Maker
Lost directions for ProSpirit Fast Wrap
press the mode button untill you get to the setting where the seconds are flashing.hit the reset button to menuver through the hours, minutes, days, and months.
Jun 16, 2009 | Watches
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Dryers Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
