Question about IBM Netfinity 3500 M20 8657 Server
Pointing device error - IBM Netfinity 3500 M20 8657 Server
Error: Unable to connect to the synaptics pointing device driver
What you need to do is go to device manager by clicking on start and control panel and find the device manager. You can also type devmgmr.msc and hit enter. Then you can see the pointer devices. You can then delete them and the right one will come back when you restart the computer you can then go back to the device manager and disable it there.
Sep 17, 2014 | Dell Inspiron 15-5547 Notebook...
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
Nov 29, 2013 | HP ProBook 4510s FM849UT Notebook
Estudio170F Device error 42
Hi:
A device error 42 is pointing at the laser giving a problem. If shutting off and turning on the fax does not clear the problem then a tech will need to look at it.
Andrew
Jul 06, 2012 | Toshiba e-Studio DP170F Plain Paper Laser...
How do turn on the Elan pointing device on an Acer Aspire?
my laptop elan pointing device is not working
Jul 04, 2012 | Computers & Internet
I recently installed vista business on my pc in the begining my philips saa7130 tv tuner was working but after getting some vista updates it stopped working pointing error code 10
error code 10 says that the device is not properly configured or it is conflicting with another device... uninstalling the device and reinstalling the drivers should fix the issue...
In most case restarting computer has fixed these kind of issues...
Jan 15, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a probleme with my asus eee 900 ;the touchpapd is not working any more can i get omme hlp have this problem for a month now
There are many reasons that your touchpad doesn't work.
First check if you have in the BIOS, the Multi pointing devices Enabled. Then go to the device manager and check it any pointing device is installed but first disconnect any other external component form your Notebook like external mouse, keyboad and other pointing devices.
The Device manager will tell you that is the status of the pointing device connected. If no pointing device appear in device manager, it means that your touchpad doesn't communicate with the mainboard even if is connected.
Scan for new hardware in the menu of device manager. If the device manager find a pointing device, restart the comuter and try if the touchpad works.
Nov 02, 2010 | ASUS Eee PC 900 Notebook
Cannot get cursor to work. What do I do?
Connect the computer to a good external pointing device, does it the external pointing device work? if answer is YES Reset the internal pointing device connector. If NO you need to replace internal pointing device. Cheers
Dec 08, 2009 | HP Computers & Internet
Dual pointing devices on HP compaq Evo N610C
Go into the the control panel and choose hardware and disable one of the pointing devices.
Aug 19, 2009 | HP Compaq Evo n610c Notebook
I am assuming that the mouse has batteries installed in it and the CD was used to install the software program for the mouse.
Did you try Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Sep 08, 2008 | Microsoft Wireless IntelliMouse Explorer
IBM Netfinity 3500 M20 8657 Server Logo
22 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
