Question about Sharp LC-26D7U 26 in. HDTV LCD Television
Cable channels wont program above 27 w my basic cable
I've had 3 cable techs and spoke to Sharp about programming my Sharp TV w/o cable box. No 1 can help me........I EZ set up and regular set up.....TV won't program above my basic cable of cannel 27
HELPPPPPPPPPPPPPPPPP
  • classmom2 Jan 24, 2009
    i CAN ONLY SELECT AIR/CABLE THEN IT GOES TO ANALOG, AIR/CABLE,
    CABLE ......i'VE TRIED EVERYTHING........iT ENDS UP ON AIR/ANALOG.......
    i THINK WHEN THE CABLE BOX WAS CONNECTED IT MESSED UP MY TV IF THAT'S POSSIBLE.....
  • Anonymous Jan 24, 2009
    I HAVE IT CONNECTED TO THE CABLE /ANALOG CONNECTION
My TEDELEX EC2159 shows me auto BG when i trai to search my channels.
Posted on Apr 30, 2016
  • 362 Answers
Hi classmom2,
I will be happy to help.
You have probably tried this but I will go over it anyway. If it dosn't work we will try something else.
From the video menu on the tv, select the tuning band of CABLE not AIR. Then do a Auto-Channel Search.
From what I gather you have basic cable without a cable box correct?
Let me know what you find and we will go from there.
Lone99star
Posted on Jan 24, 2009
  • Jason Morris Jan 24, 2009
    Which input on the tv do you have the cable connected to?
    Do you have the cable connected to th CABLE IN port on thr tv?
My sharp tv wont change channels not even on tv buttons
I am going to assume you have auto-programmed the TV. If you haven't, do so and let it finish. Make sure you are in the right mode, e.g. Antenna for over the air and Cable for basic cable.
If you have a set top box or satellite, that box changes the channels, not the TV.
If auto-programmed it and it still won't change channels you have a bad tuner and you will need a new Main board to fix it.
Feb 15, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
My magnavox 27 in TV will not let me select channels after I went to auto channel select. How do i reset it?
Be sure you have a signal connected to the RF [antenna jack] Connector! You may also have a corrupted EEprom. This is a common problem for this TV. But try the programming and be sure your menu says you are programming for Cable or Over the Air signals. And if you have a satellite or cablebox you shoud be on channel 3 or AV 1 or 2...in this case you need to do nothing..as the channels you select come from your satillite or cable box.
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
No channel 3, the tv goes from channel 2 to 4, can't use the cable box
Two options...
1. Connect the Cable Box via RCA cables (Yellow/Red/White) or Component cable if you have a HD cable box and select the appropriate input on the TV to view your programs. This will provide the best picture quality as well.
2. Make sure the cable box is on. Using the original TV remote type in the channel 03 and if this tunes to the channel then go to the TV menu and then go to Set up and then select add/erase and select add.
If typing 03 did not tune in channel 3 then using the TV remote select menu then go to set up and then make sure TV / Cable is set to cable then on the cable box press the channel button a couple of times and then select auto program on the tv.
Jan 03, 2010 | Toshiba 27AF44 27" TV
TV will not turn on to channel 4 everytime. I have a cable box and need the tv to remain on channel 4.
As long as the tv is not unplugged it should stay on the same channel when turned back on. If you have the tv plugged into the cable box, when the box is shut off it basically unplugs your tv and the tvs memory is reset. The tv should be plugged in to its own outlet or leave the cable box on and turn off the tv. If you turn everything on, cable box and tv, and have a picture, go into the tv menu and auto program the channels, it should only lock in on channel 4 since it will be the only channel the tv will receive.
May 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Feb 16, 2008 | Sharp 32R-S50 32" TV
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your tv.you cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
wg
Jan 28, 2008 | JVC AV-27D202 27" TV
Sharp LC-26D7U 26 in. HDTV LCD Television Logo
155 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
