Question about Panasonic KX-TG5672 5.8 GHz Twin Cordless Phone
Setting day and time
How do i set day and time
    New Friend:
  • 3 Answers
GO TO SETTING OPTION. THERE IS ONE PHONE OPTION. THEN GO TO TIME AND DATE SETTING.
Posted on Jan 15, 2013
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
I have model 0155671 but it doesnt look like the model online mine has four buttons across set time plus minus next riw is rnd ctd bottom is manual i dont understand when it says select 12 or 24...
A) 12-24 hour choice >> just use the 24 hour display.
That gives you day and night hours
I don't know why these companies offer 12hr-24hr option on timers.
B) Military time vs Regular time (military time does not use am and pm)
1 1am
2 2am
7 7am
11 11am
12 12noon
13 1pm
14 2pm
20 8pm
23 11pm
24 12midnight
C) Utilitec 0155671 is same as Woods 59377
Before Woods made 59377, they made 49566 (which is also called TD1101 and TD1300)
I think you have Woods 49566
Manual for Woods 49566:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Add a comment at any time.
D) How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
1) Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
2) Program review:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
3) Program the timer:
ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not hold set button down as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you will set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
4) Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 05, 2010 | Hardware & Accessories
How to program #49556 te158wta my add: gd659@cgocable.ca
Woods 49556 / TD1300 manual
http://waterheatertimer.org/Woods-timers-and-manuals.html
Set current time.
Release SET button.
Release SET button.
Release SET button.
Programing overview:
Program the timer:
Set ON
Press SET button, but do not press and hold set button as you did when setting current time.
program1 ON is set, next you must set program1 OFF
OFF
Last step:
Dec 04, 2010 | Woods Hardware & Accessories
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
How to set time on the southwestern bell answer machine FA982B
I went to the southwesten bell freedom phone site on the web. Found answering machines.  My old machine was not listed, so I found instructions for a later machine.
The method for setting time was similar.  I tried it and it worked fine.
Your high prices prompted me to be less lazy.
Jun 10, 2009 | Southwestern Bell Lands Phones
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
Panasonic KX-TG5672 5.8 GHz Twin Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
