Question about Home
How do I replace a Mr Steam MS225 temperature sensor? I am getting the prr error and was told I need to replace the sensor.
  • 717 Answers
The sensor is located in the steamer control box.
Rod
US Parts Center
Posted on Feb 07, 2013
2 Suggested Answers
  • 68 Answers
SOURCE: Mr. Steam's MS225
Steam unit should be one ( Maybe two) downspout outlets knee heighth or LOWER. Is it possible you have a body spray system also. Has the shower been used yet?? The outlets that are higher are probably for the body spray system.
Please rate this response and Good Luck, Phil
Posted on Dec 28, 2008
Mr.Steamer Commercial Steambath CU750A temp is to high it is out of control
There are only 3 likely causes. The first and most likely is the room sensor inside the shower. This is a resistive type sensor that communicates the temperature in the room to the controller via ohm ratings. There is an equivalent ohm rating for every degree of temperature it correlates to and that is how the temperature controller knows what temp it is in the room. Often in commercial steam rooms clients tend to spray cold water on the sensor which causes damage and alters the ohm rating to the point where the sensor is relaying incorrect room temps to the controller, causing high or low temperatures. Normally when the room is hot, it causes the alloy metal of the sensor to be hot. When cold water is sprayed on it, it immediately bring down the temp of the alloy and the thermal shock warps the metal causing the resistance values to change. Set your multi-meter to ohms and remove the sensor wires from the back of the controller. You will do your ohm reading on the sensor wires. Check the actual room temperature with a thermometer. At room temp 77 degrees you should be getting 10,000 ohms, at 100 degrees you should get 5827 ohms, and at 120 degrees you should get 3759 ohms. Note as the temp goes up the ohms go down, this should help you determine if your sensor is good. The other possibility is your steam solenoid valve is stuck in the open position. Simply check if there is voltage running to the solenoid. If there is no voltage but the room is filling with steam your solenoid is stuck open and needs to be replaced. The last is the controller, and by process of elimination if the sensor and steam solenoid are good then the controller may be the issue.
Feb 02, 2012 | Mr Steam Mr. Steam Commercial Steambath...
What does PRR mean?
Prr = Temperature Sensors Alarm
Mar 20, 2011 | Home
The unit turn on but does not always produce steam. is it the unit or the temperature gauge?
Hi I am with Mr. Steam tech Support, please call 800-767-8326 for help we will need your model number and serial number you can ask for ext 1288 or 1275
Thank You
Mr. Steam Tech Support
Nov 02, 2010 | Mr Steam Hardware & Accessories
Need to know what a E4 reading on the runyes autoclave means
E4 error is a pressure and temperature differential. Check the steam generator solenoid,steam generator water pump and water sensor in clean water reservoir. If any of these components are faulty then replace. If all ok refer to E2 error and check inner temperature sensor or check for steam leaks
Sep 13, 2010 | Health & Beauty
What does "prr" mean when displayed on the LED readout of the Mr. Steam control panel?
Hi my name is Mike I am with Mr. Steam Product Support. PRR is a code that shows up on our Steam Bath controls it was not used on our Sauna's. The PRR means there is a problem with the temp sensor on the control.please call me at 800-767-8326
Aug 20, 2010 | Mr Steam Mr. Steam Allegro Sauna Model...
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
Oct 03, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Mr. Steam's MS225
Dec 22, 2008 | Home
Home Logo
59 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
