Why won't tv turn on by remote or power button unless we try 4-5 times?
    Problem Solver:
  • 17 Answers
My TV has the same problem.
At first, it was an issue with the button itself, somehow some gunk got down under the button and kept it from pressing down all the way most of the time.
A few days after we fixed that, it started to mess up again, this time it was an issue with the way it transmitted signal to the TV.
If the button being blocked isn't the issue, replace the batteries. If the batteries aren't the issue and you don't have a soldering gun, then you'll need to purchase a new remote.
I bought one from walmart for ten dollars and it works just fine for basic use.
Posted on Jan 15, 2013
  • 4234 Answers
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Posted on Jul 07, 2008
  • 2187 Answers
SOURCE: how to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
Posted on Sep 07, 2009
  • 541 Answers
SOURCE: tv will not power up
These sets are bad about the flyback transformer and/or the horizontal output going bad. Have a repair shop check it out. This can be pricey depending on how much is bad.
Posted on Oct 15, 2009
  • 6 Answers
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Posted on Jan 03, 2010
  • 11800 Answers
SOURCE: I HAVE A 15 YEAR OLD ZENITH 27 INCH TELEVISION
The power went off because it was a power surge. It has fried the tv. If you are willing to spend around $250 to fix it you can keep your tv. My opinion is that your tv is gone, just buy a new one.
Posted on Aug 20, 2010
I still cannot turn off the fdp lock on my rca 20v500t
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. Try this link for more details.
Sep 26, 2012 | RCA 20V500T 20" TV
Locked rca tv and don't have remote
Without its remote control you can't unlock this TV. If you have the remote control, the proceedings are:
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sep 14, 2012 | RCA Televison & Video
RCA LCD TV locked up.
Aug 12, 2012 | RCA RCR312W Remote Control
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Jun 28, 2012 | Televison & Video
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
The FDA is lock and the TV wont stay on
Hello
The lock of RCA TV can be unlocked. You must have its original remote control to do this. If you haven't one, buy a new one or just borrow it from any of your friends or relatives who own the same model RCA TV you have. To unlock it, try these methods. One amoung them will surely unlock your TV.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Sep 23, 2011 | RCA TruFlat 27F520T 27" TV
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
I have and rca tru flat tv and my FPA lock is on... i have a brighthouse remote that im using on it but i need to know how to turn it off
Hello
Without its original remote control, opening the FPA lock of RCA will be difficult. Just try to get one new remote for this set or jut borrow it from any of your friends or relatives who own the same model set, just to open its FPA lock. After opening lock, you can use your brighthouse remote. You can open the lock with one amoung the following procedure.
Jun 27, 2011 | RCA TruFlat 27F520T 27" TV
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
Jun 09, 2011 | Televison & Video
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
