Stackable kenmore washer dryer
My kenmore stackable when in spining cycle it spash the water out of thr drum on top left side , thru the small groove .
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Could be a clogged pump or drain hose causing the water to spin over the top
Posted on Jan 15, 2013
jsrock516
  • 5911 Answers
SOURCE: water keeps draining
You may be experiencing what is known as "siphoning".  If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain.  You need an air gap in order to prevent this.  Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches.  If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests.  Makes sure there is still an air gap around the hose.  That is, make sure the hose isn't seated so tight that it seals off the standpipe completely.  This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening.  Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe.  In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor.  If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here.  There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem.  You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise.  This is air being reintroduced through the drain line.  I hope you find this information helpful.
Posted on Oct 27, 2007
  • 262 Answers
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Posted on Jan 04, 2008
  • 156 Answers
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Posted on Mar 06, 2008
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Posted on Nov 15, 2009
graemevm
  • 519 Answers
SOURCE: Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Posted on Apr 18, 2010
My dryer won't heat up. where is fuse box for kenmore stackable 41794813301
Behind this drum on the upper left hand corner is the fuse
If it was tripped however the dryer would not operate as it is tied into the door switch.
You can get a restring kit for less than 20 bucks for these
Get top off then the controls off there then remove the front like this:
The heater is on the back side of the drum so it has to come on out
I did a repair on a similar dryer last year and took some photos
Nov 02, 2011 | Kenmore 98702 Stacked Washer/Dryer
Water drains out the back left corner when the tub is filling. Water will not stay in drum. What could be the problem. Its a stackable Kenmore.
Could be the over flow sensor tube thats attached to the side of the drum has come off or one of the drain hoses. Take the front panel off by unscrewing the 2 screws at the bottom and pushing down on the panel to unlock. From there you should be able to see with a flashlight where the water is coming from.
May 17, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore stackable washer and dryer and when ever you turn the dryer off you can hear the drum grinding I can hear pennies in it would that make a difference?
You have front felt glide kit that the drum rides on and also rear bearing in back also that drum rides in. One of these is the problem and they both have to be repaired by going thru the front not the back of the dryer.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Neptune stackable -water left below the drum after cycle complete
Some water yes. a lot of water no.As long as the water stays below the wash tub you should be OK.
You might want to pull your water pump off and check for a restriction.
Mar 23, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore elite washmachine
kinked hose adjust hose so unkinked
or water pump clogged sometimes socks get past drum into water pump
water pump sends the water out
these are the main reasons the washers wont drain
couple things needed for pump removal
bucket and a couple small cups
pull water out
once low disconnect power turn the water off disconnect
you will need someone strong and a dolly
take out side the little water left in will make washer heavy
once outside tip back lay down on side angled up a little pull pump out pull debry out with needle nose pliars 2 people needed here then put pump back in done
this is self service solution
this can be done without service person
or you could call maytag
Jul 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
