Question about Boyd LuxAire II 14 inch Adjustable Air Bed
My luxaire mattress won't stay inflated and I can't find the leak or puncture. Is there a way to look for the leak or puncture?
It completely deflates within an hour.
How to inflate wheel
with a pump, if it fails to inflate you have a puncture, if no puncture the valve could have gone or if they are alloy wheels the lacquer could be peeling off this could cause wheel to leak around the rim, same if they are steel wheels cause they can rust and this can cause wheel again to leak around the rim.
Nov 03, 2016 | Cars & Trucks
Air leaking from cap on Ozark air mattress
There should be an internal one-way inflation valve that prevents leakage. The valve may be failing to close completely.
Aug 24, 2016 | Ozark Trail Velour Top Airbed Kit Queen
Do air mattresses deflate throughout the night?
When air mattresses first came out, deflating was a major issue. In the last ten years or so, all air mattresses built don't have that problem unless they have a puncture somewhere.
Feb 20, 2013 | Camping, Backpacking & Hiking
My Sealy Right Touch air mattress won't stay inflated. How do I fix it?
Hi - we originally supplied the pump for Sealy and can sell you a replacement pump that will connect directly to your air mattress. The best way to confirm that it is the pump that leaks and not the air chamber is by switching the hoses at the pump. If the same side leaks it is the air chamber that leaks or the hose. If the opposite side leaks then it is the pump that leaks. Ferdinand 905 451 7243
Nov 17, 2012 | Cars & Trucks
Should I spread my sleeping bag on a mattress?
I would recommend that you do that. I use an air mattress when I go camping. I also have one that does not require inflation for use when I'm going backpacking. Keeps you off the ground and smooths uneven terrain. I won't go camping without one.
Aug 02, 2012 | Camping, Backpacking & Hiking
My air mattress won't stay inflated. What's wrong?
If its just a small leak of air once in a while, don't worry. However, if you notice that the air is deflating considerably throughout the night you will need to check for holes.
Jul 31, 2012 | Camping, Backpacking & Hiking
Why other leter n ke board not function
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
Jul 25, 2012 | Acer Computers & Internet
How do I fix a puncture in my sleeping pad?
The best way to fix a puncture is with gorilla glue and any sort of water proof material. Just make sure the patch is completely sealed around the puncture
Jul 09, 2012 | Camping, Backpacking & Hiking
How do you deflate the northwest territory queen size air bed
I was confused by this too. Here's the trick:
When you inflate the mattress, you unscrew the square-shaped plastic cap, like this:
But this is *not* the cap you unscrew to deflate it!
To deflate it, you have to unscrew the plastic at the *round* part that's beneath the square cape -- i.e. the part of the plastic that's affixed directly to the mattress. When you unscrew the round part, the entire plastic apparatus detaches from the mattress, leaving a big open round hole where the air rushes out.
It looks like this:
Jan 06, 2012 | Baby Gear
My 2008 ultima tires will leak air to the extent they are almost completely flat. It started with the passenger side rear almost completely flat. I would fill with air and it will last for 2-5 days. Now...
Your tyres need checking for slow punctures or leaking valves. If you want to do it yourself. You'll need a tub or pool big enough for a complete wheel. Fill it with water, then, remove one wheel at a time and put it in the tub/pool. look for bubbles, the puncture is where the bubble come from.
Of course you could go to a tyre shop and get them to check, once done and you know your tyres are in good order, the only other thought is that it may be someone having fun at your expense, you could get some lockable valve caps.
Jul 19, 2010 | 2007 Nissan Altima 3.5 Sedan
Boyd LuxAire II 14 inch Adjustable Air Bed Logo
97 people viewed this question
Top Boyd Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Boyd Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
