Question about Samsung RV520 Laptop
Cord overheating when i plug in my ac adapter it gets very hot
  • Samsung Master
  • 5,660 Answers
1) Is it the Samsung AC adapter the laptop came with?
I ask because a generic aftermarket unit may cause this.
The laptop requires 19 Volts DC.
I have seen 60 Watt versions, and 90 Watt versions.
You do NOT want the 60 Watt version.
Reason?
To low a power will cause the AC adapter to overheat, and/or the laptop.
If it's a replacement it should state;
Output: 19VDC @4.74A ~ 90W
(Input: 100 ~ 240VAC 50~60Hz)
2) Laptop is not on a hard flat surface when being used. This causes blockage of the laptop's cooling system, and the laptop to overheat.
Heat = Wasted Energy
The AC adapter strains to keep up with the needed call for power, and overheats.
3) There is a part loose inside the laptop. Causing a short circuit.
May be a foreign object, and not part of the laptop at all.
This would mean wearing an ESD wrist strap, with it's alligator clip attached to a good Ground source; and disassembling the laptop to find out.
(Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
An ESD wrist strap relieves your body of Static, and keeps your laptop safe; when repairing.
Average cost is $3 to $6)
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 15, 2013
Laptop wont recognize charger
Maybe you did damage a component due to overheating? What caused the Laptop to overheat? Does the battery work on another laptop?
Dec 29, 2012 | ASUS Computers & Internet
No turn on notbook compaq 1711t
Hello The mandatory requirements before you try anything else are the main battery must be installed, it must work correctly, and there must be nothing wrong with the AC adapter or it's connection to the laptop. -Your model is recent enough the main battery must be installed - it won't start up on the AC adapter alone. - The main battery must be capable of being charged up to at least a minimal capacity. - The main battery does not last forever. Typically it works as it should for a year or so then begins to deteriorate - by the second year it can't be charged to anywhere near it's rated capacity. It gets worse as time goes by. Older batteries often develop internal shorts that makes it impossible for them to produce the voltage they're supposed to produce (you can test for that with a volt meter), and they may get HOT when you attempt to charge them for a while, rather than a little warm, or they may never get warm at all. - If you haven't replaced it since the computer was new, this model is old enough the main battery should be replaced! There must be nothing wrong with the AC adapter or it's connection to the laptop - if there is, the main battery cannot be charged properly. A common thing people do when they unplug the AC adapter is to pull on the cord rather than the plug on the end of the cord as they are supposed to do. Doing that eventually damages the plug and/or the wiring near the plug, and over a longer period of time, doing that damages the jack in the laptop the plug plugs into. The jack in the laptop should move when you wiggle the plug in the jack. Most laptops have an led that lights up only when the AC adapter is plugged in, there's nothing wrong with the AC adapter or it's connection to the laptop, and the AC adapter is charging the battery. That led should come on at least briefly when you unplug the plug from the AC adapter, then plug it back into the laptop jack, even if the main battery is fully charged. The led should not blink on and off randomlyIwhen you wiggle the plug in the jack. If that led never comes on, there is something wrong with the AC adapter or it's connection to the laptop, or the main battery is shorted (check it's voltage). If that led never goes out even after a long time, the main battery is probably no good - replace the main battery. The plug on the AC adapter cord can be replaced, but if you damaged it by pulling on the cord you will probably continue to do that at least part of the time, so since a plug molded onto the cord stands up to abuse a lot longer than a replacement plug, it's often a better idea to replace the cord from the AC adapter to the laptop if it can be unplugged at the AC adapter (a laptop repair place may stock that), or if that can't be done or you can't find that part, replace the AC adapter. The jack on the laptop can usually be replaced but that requires taking apart the laptop and careful removal and replacement of the jack. A laptop repair place does that sort of thing frequently, and often have the more common jacks in stock, though they may have to order one. Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Compaq Presario 1711T Notebook
Light around power cord goes on and off. Will not charge Plug on computer blinks on and off. The cord gets hot.
> the cord gets hot.
WARNING!
You have something DEFINITELY wrong with the AC adapter, that could ELECTROCUTE you.
DISCONNECT IT. DO NOT USE IT.
Buy a replacement (look on eBay, or look on HP's web-site: http://support.hp.com
to buy a factory-replacement part).
Dec 20, 2010 | HP Pavilion DV6700T Notebook PC
AC Power supply overheating for ASUS eee PC
If the pc is fully charged, dont leave it plugged in. Mine gets hot but I've experienced ones that were hot to-the-touch...I'd say be careful leaving it on charge when you are not at home.
Jun 09, 2010 | ASUS Eee PC 1000H Laptop
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
Nov 16, 2009 | Acer Aspire 3680 Laptop
The Ac power supply on the motherboard gets hot and stops allowing the AC power to generate power and switches to battery and eats the battery power really fast. then won't charge until PC is completely...
So the DC jack on the motherboard is Heating Up? I'm assuming the AC Adapter (charger cord) is also HOT...??
Here's what your issue is:
1. You're using the wrong volt/amp Adapter..(charger) For Example.. Your Laptop needs a 19.5v Adapter and you are using an 18.5v
2. You're using a "generic" AC Adapter and Not an OEM one.. the generic adapters will overheat and sometimes even melt due to Cheap capacitors/resistors being used..
3. You need to clean your Fan/Heatsink.. Clean the heatsink cooling fins to free blockage and stop overheating issue..
Or .... 4. Possible faulty battery
Nov 16, 2009 | Toshiba Satellite A75-S211 Notebook
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
MT6451 Display will not work.
Hello
It sounds like your AC cord or the female plugin soldered onto the motherboard has gone bad and will no longer make a connection to charge the battery or power the laptop on.
You would have to try a new power cord to find out which is the problem. If the cord fixes it, then it was just a bad cord (as you said it gets very hot, this maybe a sign of a cheap cord that has gone defective).
If the cord is not to blame, then the female plugin is loose and there is little you can do unless your an expert at soldering.
Post back with anymore questions or comments for additional help. Thank you for choosing Fixya!
Jun 23, 2009 | Gateway M305CRV Notebook
Power cords
Yes,
You will constantly draw power from the outlet. Though it may not be as much draw as if you were running a device on it. Try picking up the AC adapter one day when not plugged in to the laptop. It still gets hot.
On another note,
When using AC power you should ALWAYS plug it into the back of the device before plugging it into the wall outlet to avoid excessive power surge.
Apr 17, 2008 | Televison & Video
Samsung RV520 Laptop Logo
55 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
