Acer emachine s525.it will not power on,it refuses to charge.the charger lights up but nothing.I have tried using a different charger for another laptop it also shows that there's current coming through but its not charging.I have tried taking off my battery and charging with my original charger but it still won't power on.please or advise what the problem could be and if its worth sending it for repairs or if I should buy another laptop.
  • 7,627 Answers
The AC jack may be damaged due to pulling on the cord. Make sure the other cord/charger/transformer is the EXACT same power spec before plugging in, it may fry the laptops internal PSU.
Posted on Jan 16, 2013
  • lynn Jan 16, 2013
    Thank you soo much,I have tried most of the recommended fixes.it still won't power on nor charge but I'll keep trying.thanks to all.
benwabnick
  • 2404 Answers
SOURCE: Acer 5100 laptop doesn't work on ac or charger battery
Motherboard is bad and will have to be replaced unless of course the AC Jack on the back of the laptop is loose. That would cause the ac adapter not to charge and then you would have to take the motherboard out and put solder on each leg on the bottom of the ac jack to make sure it stays in place then the ac adapter can charge the battery properly.
Even going thru the solder method the motherboard could still be bad and have nothing to do with the ac jack.
Posted on Mar 08, 2009
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Oct 12, 2009
rcalorisian
  • 313 Answers
SOURCE: Battery fully charged, icon says fully charged but
sounds like you "MIGHT" have a bad battery. But before you go shopping try to reset you battery..
  1. I have had the same problem and emailed Acer. You need to upgrade your BIOS settings and it will be fixed. www.acer.com.au/helpdesk
    This was acers response:
    Dear customer,
    Recently it was identified that a small number customers were experiencing a problem with the battery where it would not hold a reasonable amount of charge. We have released an update that should be applied to your computer to resolve this issue. Please complete the processes below and should you have any problems please do not hesitate to contact Acer support on 1300 365 100 or log a service request online at www.acer.com.au/helpdesk.
    Thank you, Acer Support
    THey also sent me a word doc with the process and a zip file with the BIOS update. I can not upload the up on these forums but if you go to acer they should respond within 1 hr. I sent my request at 1700hrs on a Sturday afternoon and got a response within 40 mins.
    ** if you need help with that then, this is how you do it. **** After download Acer Aspire one – battery not charging.
    Solution: Update the bios as follows:
    1. Go to www.support.acer.com
    2. Click on Driver & Downloads
    3. Select Product Family “Netbook”
    4. Select Product Line Aspire One
    5. Select your Product Model i.e.: AOA150 (located after MFG.Date:xxxx AOA 150 – xxxx)
    6. Click on the BIOS tab below
  1. Just a little more information on the Acer Aspire One Battery not charging issue:
    BIOS revision 3309 (and later) has a fix for battery charging particularly the 6-cell batteries, however if you have the latest BIOS and your battery still isn't charging a good solution is to power down the computer, remove the battery and unplug the AC power cable then push and hold the power button for a whole 2 minutes (nothing will happen, we're trying to completely drain all residual voltage from the mainboard to reset it), then release the power button, install the battery and power up the computer, it should now recognize the battery and begin a normal charge cycle.
    I have read other posts that claim to hold the power button in for 1 minute which I tried and it did not work, you must hold it in for the whole 2 minutes. (which is probably what you were advised to do,as you mentioned.I just like to cover all the bases,)
I know it is a lot. But I hope it helps
Posted on Oct 27, 2009
Testimonial: "So helpful,thanks will try this first- saw other posting bout 'BIO', Acer said hold for 30 secs- then post back under warranty- not keen"
  • 6 Answers
SOURCE: battery charging,and can't run laptop on battery
u need a new battery.
Posted on Feb 28, 2010
Acer tablet will not power on . Tried resetting still nothing
Battery may be deeply discharged try to charge with different charger of same type
Jul 30, 2015 | Acer Tablets & eReaders
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
Acer Aspire One NAV50 screen blank
I am not in a position to offer free remote help, but you might help yourself with the link (below). It's to Acer's online community.
If this helps, you can indicate as much - g'luck.
http://community.acer.com/t5/2013-Archives/Acer-aspire-one-model-nav50-Drivers/m-p/57977#M39399
Jun 28, 2017 | Acer Aspire One Netbook
My e525 emachine doesnot charge i plug the charger it work when i remove it it turns off
If the charger or power brick is able to power up the computer and you can use your computer but it does not charge the battery, then the battery is most likely faulty. They only last a few years, slowly loosing their ability to power your computer until they die.
Remove the battery and plug in the power connector into your laptop computer. Power on your laptop, if it powers on and you can use it, then you need a new battery.
Contact a computer store for a replacement battery.
Take care!
damnor01
Jun 30, 2011 | Acer eMachines 520-2890 Notebook
My new acer aspire one netbook absolutely refuses to power up
if its brand new I'd suggest contacting Acer, sounds like there is a hardware fault.
Nov 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
