Question about Philips GOGEAR SA6045 MP3 Player
Mp3 Go Gear SA 1300 is not recognized by XP
After plugging the mp3 player (512 MB; SA 1300) into the USB port the player is not recognized.
XP has been re-installed on the computer. Before re-installation there was no problem. Should, next to Windows Media Player, additional software be loaded in the computer?
  • 8,596 Answers
Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> Universal Serial Bus Controllers - look to see if there are any yellow exclamation marks next to any of the USB ports. If so, right-click them and select Update Driver. Good luck!
-Tha Mp3 Doctor
Posted on Feb 07, 2009
No power mp5 i use a cell phone charger in my mp5
What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
And secondly After testing for charger, and still it does not charge, that means the charging port on the mp3 player where the charger is been plugged in is not working properly. You will need to replace the charging port.
Alternately you can charge it from your computer by using USB cable. It automatically charges when connected to a USB port
Dec 06, 2010 | JVC XA-MP51 (512 MB) MP3 Player ()
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
Computer does not recognize MP3 after reinstall
When you connect your mp3 player to your PC, it will appear in "My Computer" as a removable drive. If it does not, the USB port may be the problem. Plug a different device into this port to make sure it is working. If it is not, make sure you have all the drivers for your computer inastalled. Also try a different USB cable.
Nov 13, 2009 | SanDisk Sansa Clip MP3 Player
My XP system does not recognize Sandisk Sansa e260
The XP did not recognize the device because I used a after- marked USB expander board that did not provide enough power to the device. Plugging to the Motherboard - attached USB port solved the problem.
Mar 20, 2009 | SanDisk Sansa e250 MP3 Player
I got an ilo mp3 player from a friend, i plug into the computer and computer doesnt recognize device
If the computer is running the Windows Vista operating system, your mp3 player is not compatible with it. If it is running XP, load any software that might have come with the player. Then check all USB ports on the computer. If none of the ports recognize the player, hold in the volume + button while connecting the mp3 player to the computer. Good luck!
-Tha Mp3 Doctor
Dec 08, 2008 | iLO (2 GB) MP3 Player
Joybee 130 MP3 plaer
Plug your player into your computer via USB. If Windows recognizes it, a new drive should show up under "My Computer". It may be called "Removeable media". It may be some letter like "G" or "H". If you have an SD card bigger than 512 MB, then find the removeable drive that is bigger than 512 MB that shows up when you plug in your MP3 player and that drive is your SD card.
May 02, 2008 | BenQ Joybee 130 MP3 Player
Stuck m230
to put your mp3 in MTP go to settings, and then to usb mode, then click in MTP, i don't know how to solve the rest of your problem, sorry, hope you find a cure
Jun 17, 2007 | SanDisk Sansa e250 MP3 Player
Its not plug and playing Sandisk 240m 1g
Hi blackmajik, I just got a Sandisk m250. Windows wouldn't recognize it either until I updated my Windows Media Player to version 11. Now XP sees it just fine and the MP3 player syncs with WMP and accepts and plays music!
Jun 07, 2007 | SanDisk Sansa m240 MP3 Player
Mp3 wont work
Just format it and reinstall the firmware.
Jun 16, 2006 | Coby MP-C541 (128 MB) MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
248 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
