Question about Pool & Spa
Heater won t get up to 100. Stays at 90. ?????
  • 1,631 Answers
If mechanical, - bad thermostat. If solid state/digital (with a circuit board) - bad temperature sensor.
Posted on Jan 16, 2013
Number of 175ml bottles needed to fill 5.30 glasses for 100 persons
Interesting conundrum, since we have to guess what 5.3 means.
If it is an ounce: 1 oz = 29.5735296 m (lets round up to 29.6)
(29.6 * 5.3 * 100) / 175 = 89.64571428571429 (lets round up to 90).
It it stays in milliliters: (5.3 ml * 100) / 175 = 3.028571428571429 (lets just round to 3).
Hope this answers your question.
Mar 05, 2015 | Braggs Organic Apple Cider Vinegar, 12/32...
When set on timed dry the flame for the heater box ignites and starters up stays on for 90 seconds and cycles off. Cycle on after 3 or 4 mins. Stays on 90 seconds. Than cycles off. Dryer continues to run...
You need to give us make and model number(s) for everything.
You may have luck in finding one of us who has a valid answer right away.
Jan 12, 2015 | Dryers
Stays in defrost to long
There is a defrost termination thermostat located somewhere near the defrost heater, probably on one end and a bit above the heater. These are located in the lower part of the evaporator coil (the cold coil in the freezer) so you will have to disassemble the freezer to access this. This usually involved removing a cover, but may be more involved depending on your brand and model. Follow the heater wires and one of them should connect to this stat. Stat cut-out temp settings vary, but should be between 40 and 90 degrees - it should be marked on the side of the stat, depending on the location and type of defrost system. If this thermostat is stuck in the closed (on) condition it would account for this sort of failure. Some newer refrigerators use solid state controls with different control systems for defrost so you would have to determine which type you have, but the mechanical thermostat is most typical. It is approximately the size of a quarter, perhaps 1/2 inch thick and typically has a brown and orange wire. Also, look for shorted/burnt wiring since a shorted wire could touch the case and bypass the controls, accounting for this failure mode.
Sep 13, 2014 | Refrigerators
Oil temp overheating (slightly over 90), cooling fan stays on temprorarily when car is turned off. Vauxhall Corsa 1.2 litre
90 deg C is normal for a vehicle standing for some time. What does the temp read when the car is on the highway doing around 100 km/h.
Feb 03, 2014 | Vauxhall Cars & Trucks
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My minimax nt only heats till 90 degrees. I set it up to 104 which is the highest and it only stays at 90 degrees. Everythig seems to be working well, no errors either. Please advice.
Either the thermostat board is defective, the temperature sensor is defective or not enough heat is being produced by the heater. . I recommend you call the Pentair technicalsupport at 800-693-0971 and they should be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 25, 2011 | Pentair Minimax NT Heater
Check engine light comes on in my 2000 tdi automatic golf shortly after starting .It then goes through the gears until it hits third then it stays at around 3000 on the tack at 90/100 kmh and won't...
Hi!
It might be the reason why the check engine light come on. And all i can say is you need to scan your can and pull the code and bring it back to see whats wrong because it maybe some to do with Transmission shift solenoids usually when they get stuck open or close a code gets stored in the ECM. Good luck
Jun 05, 2011 | 2000 Volkswagen Golf
Goodman GMP 100-5 Rev B Serial # 9902602550 The status light stays illuminated. It isn't blinking. I believe my igniter went bad. When I turn on my heat on the system, The exhaust fan kicks on,...
Hello, the first thing is check the igniter for any crack or white spots on it, also, if you have a multimeter check the resistance of the igniter, should be between 40-90 ohms. You can purchase a igniter at any Heating and Cooling supply store.
Mar 11, 2011 | Goodman GMS90703BXA Heater
Sta-rite pool heater SR333LP
This heater has a thermal regulator and a high limit that could be the problems. If it were a high limit that was bad, the display would show the error when the heater goes off. In the absence of an error, one would look to the regulator. A bad regulator would cause the water flow to bypass the exchanger and cause a slow heat. The part is easily replaced and runs about $90. It sort of looks like a car thermostat and also has a spring. It is accessed by removing the large black plug near the plumbing inlet/outlet.
Dec 16, 2008 | Sta Rite Sta-Rite Max-E-Therm High...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
