Error code C-0413 konica minolta buzhub 6500
I started the copier and gave me code c-0413 , i off it then start and warm up, i printed some copies it comes back, when i look at code details ( Fan heater Up HTR3) rising temperature abnormality, and (TEMS /3) . Please help Thanks
  • 1003 Answers
SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
jqsababa967
  • 145 Answers
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Posted on Dec 03, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
Cogz
  • 1326 Answers
SOURCE: error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Posted on Jan 24, 2009
Error code 6508
Could not find a Error code c-6508. But I did find a paper jam 65-08. Check you document feeder there is a jam paper or sensor problem (PS302).
Mar 23, 2015 | Konica Minolta Bizhub C 6501 Color...
How can i do for error C6702
http://www.copytechnet.com/forums/konica-minolta/30879-konica-minolta-biz500-code-error-c-6702-a.html
guy does eventualy fix it on later pages
worth a good read
i got board half way down
a good tip with rollers {rubber not sponge} is too use white vinegar wipe it on leave it to dry
and run few some fully black sheets...prints
then it works magic
Dec 09, 2014 | Konica Minolta Bizhub C 6500 Copier
Konica minolta 6501 error code c-c101
had a circuit board replaced recently??? if so check each and ever connection, pull each connection and reseat each connection one at a time while each connector is removed check all pins for a bent pin. Or replace the Print control board, Interface control board, image control board, and the overall control board, $$$$$$$$$$$$$$$$$$$$$$$$$ more then what you paid for the machine!!!! Then you will still have to remove each connection and reseat them and look for bent pins!!!!!
Jul 03, 2014 | Konica Minolta Bizhub C 6501 Color...
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
My konica Minolta buzhub 362 copier shows error 3452
Restart the machine.If code removes then its OK, otherwise press the utility/counter button and restart the machine.Don not leave the button.Keep the button pressed.Trouble reset will appear on screen hit it and restart the machine.
Nov 21, 2012 | Konica Minolta Bizhub 362 Copier
Bixhub c351- I can copy in duplex but i can not print in duplex
Have you told the print driver that you have a duplex fitted, also is the paper set as plain as any thick setting will cancel out the duplex function.
Jun 16, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
May 11, 2009 | Minolta C350 Printer
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
106 people viewed this question
jasbo
jasbo
