Question about Kenmore 98702 Stacked Washer/Dryer
Washer Doesn't Start
When we select a cycle and pull the knob to start it, no water comes out, but it sounds like it engages. We used it for three or four loads yesterday and everything was working fine.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Once again check your lid switch where the lid hits when you put the lid down
Posted on Jan 15, 2013
catriver
  • 878 Answers
SOURCE: Washer Machine does not work properly.
MR, Im assuming that your model starts with 417-44102. There could be a number of problems here but lets start with the drain pump itself. On this model, even though the tub looks empty there could be water under the basket. There is a pressure switch that will not allow the unit to spin if it detects water in the tub. I have found on many occasions that the pump has debris in it preventing a full drain. If you drop the bottom panel you will see the pump on the right side bottom. Get a pan, remove the hoses and clean out the debris. Another thing is you want to make sure that the hot and cold water are turned on to the washer, it will not advance if they are not turned on. If these areas check out ok, then some detailed tests will have to be made on the motor controller. Catriver...post back
Posted on Aug 14, 2006
  • 641 Answers
SOURCE: front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Posted on Jul 23, 2007
danromarris
  • 101 Answers
SOURCE: washer makes noise during spin cycle, wont agitate
Sounds like your transmission is going out. Yes washing machines do have transmissions, I know, strange huh? Anyway, the transmission is connected to your motor and the motor makes it spin and agitate. The transmission goes up into the tub and is basically the agitator. When the gears go bad in it, it will start making a loud noise almost like a grinding noise and won't spin properly or agitate. It is expensive to fix, almost as much as a new washer. Your best bet is to buy a new machine unless you can find a good deal on a refurbished transmission. Those will sometimes run only around 150 dollars. A new one though will cost you around 250. You might be able to find a good deal though. They are easy to fix, I myself replaced one in 15 minutes once when I was still a repair man for Sears. So, check out some prices and see what the best way to go is for you. If you have any questions about installing it let me know and I can give you an easy step by step walk through on it. I hope this helps you out and good luck.
Posted on Jan 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Model 970-C41074-00. Front Load
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: washer will not start cycle
It appears your timer/main controller/CCU has failed in this instance.
Posted on Sep 18, 2010
Model gfwn1100 front load washer
It shuts down because of time out, is the water turned on, sounds stupid but it has happened several times, I go on a service call just to turn the water on to the machine.
Feb 03, 2014 | GE Washing Machines
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Kenmoore 800 washer doesn't do anything
Possible that the timer controller is faulty as it fails to switch or move in the cycle of the program
Use WD 40 to clean the switch, the knob can be replaced if this turns loose.
Jan 25, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
I have a Maytag dependable care quiet pack 2 speed super capacity 9 cycle Model No. LAT9416AAE
It is possible that you need a new timer which is a part number: 22003362 and is usually about $75-$100 but it is also possible that one of the components of the knob is not functioning properly. The best bet is to take the knob apart (make sure the arrow points to a wash cycle first) and then pull up on the time timer shaft itself. If the washer starts then you know its one of the components of the knob that when bad. If it doesn't then you know you need a timer.
Nov 16, 2012 | Maytag Dependable Care LAT9706
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
GE washer selection knob doesn't engage
The knob it probably stripped. i would replace.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
