Question about Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF
Ricoh aficio mp3010 ,i will change n?ew toner then againe coming add toner mesege,why
  • Ricoh Expert
  • 1,326 Answers
Have you replaced the developer yet???? It could also be the unit that the toner bottle goes into. There is a paddle wheel inside of it that move the toner and it may have broken up... Good Luck
Posted on Jan 16, 2013
SOURCE: add toner
replace toner supply unit. inside of the unit are 4 mylars to push toner towards hopper exit gate. looks like them mylars are ripped off and the toner is not getting to the dev unit
Posted on Oct 26, 2008
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
  • 1297 Answers
SOURCE: my ricoh aficio mp3010 keeps comming up with error
You need acces service progpam:
1. Press the clear modes key.
2. Enter 1-0-7.
3. Press the clear/stop key for more than 3 seconds untill the service program menu appears om the touch pamel display.
4. Enter in the service menu.
5. Turn OFF the power switch,unpluged cords,wait 10 sec,plugged cords then turn ON power switch.
Posted on Aug 02, 2009
  • 1297 Answers
SOURCE: my ricoh aficio mp3010 suddenly only gives my blanc
Your problems into the high voltage unit.Please check the carge corona (wire & holders&grid),inspect transfer bellt (under belt HV board,inspect and vacuum cleaning the toner and dust).Pull out the image unit ,rotary manual magnetic rolls to see a developer status,and reinstal the unit.
Ricoh aficio mp 1600 add toner problem ?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
May 01, 2014 | Ricoh Aficio Mp-1600 Copier
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Jan 28, 2010 | Office Equipment & Supplies
My ricoh aficio mp3010 suddenly only gives my blanc copy's.( I allready changed the toner, but stil no succes. could someone please advise. thanks.
Aug 02, 2009 | Ricoh Aficio 450 Copier
My ricoh aficio mp3010 keeps comming up with error sc 548 any body now wat to do. please help me
2. Enter 1-0-7.
Cl2000n Ricoh can't reset add toner cyan in display
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Ricoh Aficio CL2000N Laser Printer
I HAVE CHANGED THE TONER CARTRIDGE AND THE SIGN TO ADD TONER IS STILL ON
I have changed the toner cartridge and the sign to add toner is still on.
Jul 21, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF Logo
219 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
