Question about Philips Televison & Video
Plug in power cord on phillips 40pfl4707 and a/c fuse in tv blows
  • Philips Master
  • 933 Answers
You have a short on the front end of your power supply board!
Posted on Jan 15, 2013
5 Suggested Answers
satavlad
  • 405 Answers
SOURCE: error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
Posted on Dec 04, 2009
SOURCE: Element LCD tv with no power. I replaced fuse,
You probably need a new power source. Take it to you repair shop. That's what I had to do and it was relatively inexpensive.
Posted on Mar 23, 2009
SOURCE: Element FLX 3211B has no power after 14 months of
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Posted on Apr 27, 2009
  • 212 Answers
SOURCE: blows fuse internally when tv powered up
There is a short in it somewhere. check the ground.
Posted on May 24, 2009
Philips 40PFL4707 screen cracked
Nothing can be done, except replacing the screen with a new one. Contact the authorized service center for Philips.
Oct 25, 2013 | Philips 40PFL4707 40" 1080p LED-LCD TV -...
Philips 42pfl3704d/f7 No power at all
its definitely the fuse. you have to go to the phillips website and type in your model number to get the right fuse. I went thru 3 different fuses and they all blew right away. phillips website sells the right ones 5 bucks each. Get it here and it will save you trouble trust me.
If nothing happens no light or sound when you plug it in to the wall it is definitely the fuse. mine was a T8AH250VP. You have to be sure to get that exact fuse. every letter exactly like that. there are a lot of similar fuses that will blow the moment u plug it in.
Hope this helps took me a month to figure this out. I was going to buy powerbaords for no reason. fixed my 42 inch phillips for under 10 dollars. couldn't be happier. Also always run your tv threw a power ack. If you plug directly to the wall your fuse will blow frequently.
Sep 23, 2012 | Philips 42PFL3704D LCD TV
How many amps is the fuse that is located on the back of the TV near the power cord. It says T5AL/125 or 250 v. f800
Something else is going on to cause the fuse to keep blowing. Sounds like you have an issue on your power supply in the unit. Also check the outlet that your plugging it in to. Good luck!
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
Whistler 1730 keeps blowing fuses. no other problems with cigarette lighter plug
Is the lighter socket fuse blowing or the fuse in the unit's power cord? Have you tried another power cord from a Friends radar detector? If it doesn't blow that power cord's fuse, then your power cord is bad. If it does blow the fuse in the other power cord, there could be something wrong with the unit. Contact Whistler at info@whistlergroup.com
Jun 15, 2011 | DE-1730 Radar Detector
Won't switch on
yes it could be a fuse but moust of the time
the fuse is blowing because power suger/or bad flyback/hozoutput/or power supply whent bad. unplug the tv .take off the back and look for the fuse you see the power cord it by the powercord if the fuse is black it a hard blow.
if you can see thur it .it a sofe blow you can try to chang it.6.1amp fuse125v or it could be 250v fuse6.1amp and if the fuse blow agon you have a short powersupply
Jun 02, 2009 | Televison & Video
TV TROUBLE SHOOTING PROBLEM
Have you tried another outlet in the house? If it still blows a fuse there could be an internal issue in the TV regarding grounding. Can you temporarily connect a microwave oven or similar device to that outlet to see if the fuse still blows? If it continues to blow, you can at least rule out the TV being the cause. Is the TV new? Has any recent electrical upgrades been done? Are you using an extension cord or plugging the TV's power cable into the Cable/Satellite box instead?
One important step to do regardless for all sensitive electronics is to perform a power drain by unplugging the device or removing batteries followed by holding in the products power button for 1 minute. This flushes out the capacitors and circuit board of any electricity that can prevent normal functionality.
Oct 14, 2008 | Philips 27PT543S 27" TV
My phillips 42" flat screen model number 42pf7621d/10 keeps blowing the fuse in the plug usually after we have turned the tv off and its in standby mode or overnite when we sleep ive just change...
What is rating of fuse in your TV like amperes and volts.
There is Thermistor in TV for degaussing the picture tube while in start up. This part requires heavy current to work for a second or two.
You can increase little bit current rating of fuse to avoid blow off.
Oct 01, 2008 | Philips Televison & Video
Televison & Video Logo
444 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
