Question about Solar Abstract Blue Green Switch Plate Set Light Cable Double
The ABS light has come on in my 53 plate Renault Clio
    Problem Solver:
  • 10 Answers
Had the same light Found on the web that our problem was the bad connector to the seat belt under the passenger seat . A disconnect and reconnect of the joint fixed problem
we also had the Sensor ring (split) on the drive shaft break which caused intermittent problems. Renault want you to buy a whole new shaft but u can buy the rings only and fit them .
Posted on Nov 26, 2014
  • 10,865 Answers
That is the light connected to your antilock brake system. More often than not the problem is a faulty sensor and not an actual brake problem. Do you still feel the antilock brake pumping action when you brake? If yes, your antilock brake system is still operational, if not then you simply have conventional brakes which would require you to pump the brake pedal if you were driving on slippery roads. Good luck.
Posted on Jan 24, 2009
Can I adjust the clutch on my 53 plate Renault clio
There are Garage websites out there now which allows you to put in the repair and garages will contact you with a price locally. According to which model clio you have the clutch kit on ebay are from 40 - 80 pounds in the UK .
Contact a local independent garage or mechanic for a price .
Jan 02, 2015 | 2003 Renault Clio
Renault fault codes
hi there i have a renault clio 57 plate 1.6 auto. it keeps going into safe mode on the gearbox intermitantly. i have read auto trans fault codes which are df241 df240 df242 df243 and df231 which relate too abs sensors.have you any ideas thanks
Apr 29, 2014 | 2002 Renault Clio
Renault clio 1.5 dci speedometer not working handbrake,abs,and service light all on continuesly
your abs system is faulty vehicle gets speed info from abs comp and the lights are to warn you of the abs fault
Mar 31, 2013 | Renault Cars & Trucks
Back Brake problem Renault Clio 53 REG UK
Try pulling the bulb and clean the socket may be shorting
Apr 28, 2010 | 2003 Renault 181
Where do I find the serial number of a windscreen wiper motor in a Renault Clio 53 plate?
doesnt have one not that i have ever noticed ,just take it out and then go teh spares shop with it in your hand .sorted
Dec 21, 2009 | Renault R18 Cars & Trucks
Have renault clio 53 plate expression with leaking sunroof which is on passenger side by sun roof - any clues or idiots guide as to how I can repair plse?? Damsel is getting wet!!! Thanks
There is a special sealer tape from RENAULT or get sealer from B&Q and go around the rim between the car roof and the sunroof all the way round
Dec 17, 2009 | 2006 Renault Le Car
Radio code
Your code is 4732
Jun 02, 2009 | 2003 Renault 181
Solar Abstract Blue Green Switch Plate Set Light Cable Double Logo
510 people viewed this question
Top Solar Electrical Supplies Experts
Steve
Lawrence Oravetz
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
