Question about Furniture
Part # CBE2303 G/B Brace for Model # CR4824 is missing a rivet.
Just purchased shelving at Lowe's yesterday.
    Problem Solver:
  • 7 Answers
EEWWWW! This has happened to me more than I care to mention.
I used to take the item apart and return the whole thing. After many times hauling around heavy boxes, I learned a trick.
Take one of the pieces you need back to where you bought the item. Explain what happened and show the part and the RECEIPT. Most likely they will just give you a replacement part on the spot.
Posted on May 10, 2013
Recent purchase of Hunter Fan #21648. The following items were missing: Pull Chain Pendant - Pull Chain Extension - Light Bulbs I tried for over two hours to contact you at your 888 number. Each...
James, you can pickup the missing parts from either Home Depot or Lowe's for less than $8.00 and not have to be left waiting on hold for over 5 minutes. FYI - In most cases, light bulbs are not included with the fan. They are shown in the Owner's Manual as a recommendation.
Thanks for choosing FixYa.
Aug 10, 2011 | Hunter Heating & Cooling
I have a troy built pressure washer model no. 010245-1. the screw (not pressure valve) is missing from the bottom. To replace, what size would I need to buy. And can I get the screw from Lowes
You can probably (like 90% sure) get the bolt at Lowe's, however I can't seem to find your model number. Your best bet would be to lug the thing in there with you, then sit down in the bolt aisle and try them out :)
Jun 15, 2011 | Briggs & Stratton Garden
I need to replace the pull string on my toro personal pace mower. The toro part appears to be riveted to the body of the mower. All other mowers the part you need to remove to attach the pull string to is...
If I'm not mistaken, I had one like this once. I think when you purchase the new one, it comes with screws. You have to drill out the rivets to replace the recoil assembly. Try calling to purchase a new assembly and question them.
Gary
Jun 07, 2011 | Toro Power Lawn Mower
Need to buy a handle light for weber family 300
Weber doesn't have a handle light for the 'Q' Model grills. But, you can purchase a generic clamp-on handle light from just about any home center (ie.Lowe's & Home Depot) or hardware store (Ace or True Value) that sells gas grills and accessories.
Hope this helped you. Please let me know. Thanks and Happy Grilling!!
May 16, 2011 | Weber Q300 Grill
GSS25LGMCC Side-by-Side. On left freezer side, foam filled walls have contracted and top two wire shelves can no longer rest of molded side supports and fall. Need shelves about 1/2" wider
never heard of that happening,are you sure you're not missing a support that the shelf slides on or you have the wrong shelf for that spot.i'm sure you tried the shelves in all the slots,if the wall did push out like you say the only thing i can suggest is to buy another support and get longer screws and put the screw through both supports and hang them like a single support to make up the difference.next what caused this to happen,is the freezer staying cold?if you give a parts store your model number they will sell you the same shelves that you have.
Apr 30, 2011 | GE GSS25LGM Side by Side Refrigerator
One of the rivets on the cross mechanism has broken off. How do I get this repaired? We bought the pram in November 2009.
Two solutions:
Traditional requires removing the damaged rivet.. at times this requires drilling the remains of the damaged rivet out.. Most of these rivets are "Pop Rivets". You need a Pop Rivet tool and of course the new rivet. The alternative to purchasing the tool and the appropriate size rivet. (Some hardware stores sell the rivets in different sizes by the each). Take the stroller to a sheet metal shop (Furnace A/C installer) or a Auto Body Shop.. both places will have the Pop Rivet tool and probably boxes of rivets.. if the old rivet is missing completely..and they have the right rivet and tool..it's a 10 second repair.
The other alternative.. is a fastener type referred to as "Well Nuts".. this is a rivet like device that you can install yourself.. two pieces.. a threaded insert..and the threaded mate. It looks a lot like a rivet when installed.. usually no special tools required. Good hardware stores may have them.. and it may just do the job.
Most of these rivets on your type of stroller are located in places that require them to be as flush as possible for obvious reasons.. folding.. and safety. If this one is not subject to either. A simple round head phillips screw of the right length and self locking acorn nut will suffice.
Best of Luck
Apr 25, 2011 | Silver Cross 3D Standard Stroller
Purchased a used 13.4 cubic freezer from caigslist yesterday. Upright type. Freezer is set on 7 to cold setting. Shelves are the type where the shelve itself cools the food. No fan in this model and it is...
It takes a while for this type of freezer to pull down in temp. because there is not evaporator fan for air movement. I would watch it for at least 12 hrs .
Nov 07, 2009 | Heating & Cooling
No shelf
I have 2 shelves and a chrome drip pan from a Farberware T4850. They are used but in good condition. As far as I know, all the shelves for the Farberware T series convection ovens are the same. My T4850 just stopped working a few days ago, and I am looking to replace it. I would be willing to give you the 2 shelves & chrome drip pan (which you may be missing and are unaware of it). If your interested, do the research to make sure the shelves are the same. You can e-me at allennyc@verizon.net. Shipping is on you
Allen
Jan 04, 2009 | Farberware T490C 1500 Watts Toaster Oven...
Furniture Logo
248 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
