My msi is going on to the start screen and going on to restore but will not let me use my mouse, keyboard or tapping the screen to click enter, how do i do it? HELP
    Scholar:
  • 127 Answers
Try a USB keyboard to see if it makes any difference
Posted on Jan 15, 2013
3 Suggested Answers
  • 10406 Answers
SOURCE: Mouse & keyboard not working
You're "stuck" -- if the circuitry for the PS/2 keyboard and mouse is not working, and if it does not recognize a USB keyboard, the motherboard must be replaced (by an identical moetherboard, if you can find one, or a "newer/better" motherboard that takes the same CPU and RAM as your current motherboard).
Posted on Jul 30, 2010
bronk50
  • 27725 Answers
SOURCE: mother board MSI G965 dont start. After power on,
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
if this does not fix
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 05, 2010
When I Start My Acer Aspire 5336 Laptop, And Continue To My Password Screen, My Keyboard Will Not Work, Even The Mouse Pad. How Do I Fix It?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 24, 2013 | Computers & Internet
How can i get rid of Dxerror 8876086C
Step 1:
Feb 22, 2013 | Logitech QuickCam Computers & Internet
Fatal system error 0x0000135
Step 1:
Feb 15, 2013 | Dell Computers & Internet
Turn on error 00173 ,00301,00163
Feb 13, 2013 | IBM ThinkPad 600X Notebook
0x00000ba how can solve this error
Feb 12, 2013 | Computers & Internet
Starting problem it is asking me retstart some it dnt starts
Feb 10, 2013 | Computers & Internet
Vaio stuck on vaio screen
Try booting to safe mode. Restart your computer or turn it off and turn it back on. While it's starting, tap F8 until you see the options to boot to safe mode. If you see that screen, then use the arrow keys to highlight safe mode and press enter. If it goes in, then do a system restore by going to START > Programs > Accessories > System Tools > System Restore.
Restore it to a known good date (the date when the issue was still not there).
If you cannot access safe mode, then you have a more serious problem. There are two possible reasons of that certain issue> 1. Operating System Failure which is easy to fix. 2. Hardware issue which needs the expertise of a technician. If you can't get into safe mode, then I suggest that you get the services of a technician.
I hope this helps!
David
Feb 08, 2013 | Sony Vaio Vgn-C140 Vgn-C190 Vgn-C290...
Does not turn on
Step 1:
Feb 06, 2013 | Sylvania G-Netbook
My computer want start and every times I starts it it say error and please restart
Feb 04, 2013 | Computers & Internet
Power up issue resolved, A8N- SLI booted up in the main screen of BIOS, after entering the delete key nothing would happen. Tried numerous times, retarting still nothing. Cleared the cmos, nothing, tried...
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
hope this helps you
Sep 02, 2011 | ASUS A8N-SLI Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
