Hello Gary Tower - A few things to consider, when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken straws, pits, etc. You should simply be able to grasp handle, lift out, empty and place it back. Check for blockage at garbage disposal and drain for blockage. Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Humming noise is due to loose connections on drain pump or due to faulty drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Hi
Hi
Hi
Hi
Hi
