Question about Canon Rebel XT / EOS 350D Digital Camera
I have a Canon eos Rebel XT. Once powered on it will take photos for a short time, get hot and power off by itself and won't power back on till it cools off. Additionally once powered on even when
All details were added above
    Novelist:
  • Canon Expert
  • 357 Answers
Remove back cover and check for missing screw - especially check if it is touching the orange wire that powers the back light for the rear LCD that s part f the rear cover. Screw that is loose is almost always the bottom right screw that holds on rear circuit board. If it is not there and you see the empty hole, it could be anywhere in the camera, so you will have to keep on disassembling until you find it.
Posted on Jan 27, 2013
  • 619 Answers
SOURCE: My new Canon Rebel EOS XT will not work with my external flash. WHY??
Hi , connection from camera to the quantary ps-1 dszflash are compatible the adopter it connect during flash signal.You may return and bring your camera and test what ever compatible.
Posted on Jan 25, 2008
  • 7 Answers
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Posted on Aug 22, 2009
  • 30 Answers
SOURCE: my canon eos rebel xt 350d wont focus
change your manual settings
Posted on Oct 11, 2009
  • 30 Answers
SOURCE: we have a Canon rebel XT EOS the flash pops up no matter what the
Frustrating I am sure. I had the same problem on my first XTi. I cannot remember what the settings were, but I think I was set for portrait and had flash set as the white balance default source. Therefore the camera always popped up the flash assuming that I wanted or needed fill flash.
Change you white balance to sun/shade/tungston etc as is appropriate, choose a faster ISO speed in lower light levels and try using the P or Tv mode and use a shutter speed that generates a middle range aperature for your particular lens.
Posted on Jan 28, 2010
SAFFOTO
  • 77 Answers
SOURCE: Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Posted on Feb 03, 2010
Bought cannon rebel xt 350d used and it did not come with disc. how do i know what to install so i can download my pics?
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery.
Sep 03, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have a cannon rebel XT EOS 350D. I can not get my computer to recognize the camera so I can view the pictures or download them to a file.
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 10, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Trying to upload photos from my canon rebel xt, but a busy signal keeps flashing. What to do?
Feb 02, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT won't connect to computer, tried the ptp setting, still didn't work. It is not a driver issue, as it worked earlier today. On the screen it says 'Busy'.
Consider NOT connecting your camera to your computer.
Sep 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I have problems downloading pictures from a Canon eos 350d to my new computer (which uses Windows 7).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
May 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Aug 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT
It is normal. Camera lightens surrounding to get focus point.
Oct 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
