Question about Dryers
I have a Bosch Tumble Condensor dryer - Dryers
I have a Bosch Tumble Condensor dryer WTE6920GB/01-V02 which heats up the clothes but then (usually after one successful load) and stops I am thinking its the thermostat or moisture getting into the control panel If its the thermostat which one is it? It is 9 years old but as its an integrated dryer I cannot buy a new replacement as they no longer maker integrated condenser dryer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Dryer motors have a thermostat in them ,when they run a while and get hot they knock off for a while till they cool down
Posted on Jan 16, 2013
  • fountapb
    fountapb Jan 16, 2013
    Could be that but the dryer will normally restart immediately and there's no electrical burning/hot smell I would have expected if it was the thermal cut out.
    Thanks
5 Suggested Answers
  • 18 Answers
SOURCE: gas smell from dryer
your igniter needs to be replaced.
Posted on Feb 04, 2007
gittos73
  • 244 Answers
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Posted on Aug 15, 2007
  • 254 Answers
SOURCE: my gas dryer has no heat
long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
Posted on Feb 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Smartheat Quietpak 9 HE4 dryer taking longer to dry
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
I would like to download an instruction manual for my bosch tumble dryer wte6920gb. Please can you advise.
You can find your manual here: http://www.bosch-home.co.uk/download-product-manuals.html
May 04, 2011 | Microwave Ovens
Bosch Exxcel Drier WTA4107GB/01 not heating up. Is there a reset button
yes and here is the thread on it:
http://reviews.ebay.co.uk/Tumble-Dryer-Not-Heating_W0QQugidZ10000000001966118
Jan 11, 2011 | Bosch Dryers
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
Apr 09, 2009 | Bosch Dryers
Bosch condensor tumble dryer error code F:09. Any thoughts? I can't find it via google. Many Thanks
Did you ever get an answer - if so just had the same problem and was wondering if you could let me know by posting here.
Jul 09, 2008 | Dryers
Tumble dry is heating but takes forever to dry
check your air exhaust (including the lint filter) from the air duct connector (remove duct if necessary) on back of dryer to the exterior of the building. Somewhere, there must be air blockage.
Jun 17, 2007 | Creda IWD12 Front Load Washer / Dryer
Dryers Logo
403 people viewed this question
Top Dryers Experts
