Question about B&W DM602 S3 Speaker
My b&w dm602 speakers sound strangled
I get some sound but not much. The base speaker does not work.
  • B&W Master
  • 19,110 Answers
Blown/scratchy speaker
Based upon your brief description, it sounds like the internal speaker itself has worn out (likely cause) or possibly the internal speaker wire(s) may become disconnected or may be shorting out.
LeapFrog has discontinued product support of our "Learn & Groove" Musical Table with green legs that was made in 2010. LeapFrog Customer Service declined to discuss replacement parts, so I searched eBay for an exact speaker replacement.
BTW, I am not affiliated in any way with the eBay seller nor do I work for LeapFrog... I'm a Computer Engineer/Geek in Cincinnati, Oh trying to solve a simple toy problem. All opinions expressed are solely my own and do represent any technical guidance from the original equipment manufacturer.
Correct replacement speakers are available on eBay and ship from Hong Kong... I just bought qty2 of these speakers for $5.69 total inc s/h/p (only 1 was needed). Delivery time was slow, but well worth the wait...
When the replacement speakers arrived, I had to take off the back panel screws and unsolder the original speaker, so I could resolder in the single replacement speaker under the 2" black cover. The "Learn & Groove" Musical Table speaker now works great!
Some forum posts say that resoldering a computer modem speaker (16ohm .25w) could be used, but this is a temporary solution at best. The replacement speaker from Hong Kong produces a better quality sound and more sound volume when used with the "Learn & Groove" Musical Table.
The speaker replacement specs for the LeapFrog "Learn & Groove" Musical Table with Green Legs are as follows:
"Round Aluminum Shell Magnetic Type Slim Speaker Horn"
.25 watt
Resistance 16 Ohm
Type Internal Magnetic, Slim
Shape Round
Bottom Diameter 20mm/ 0.8"
Outer Diameter 35mm/ 1.4"
Height 9mm/ 0.35"
Material Aluminum, Metal, Plastic
This replacement speaker worked great for me and now my Granddaughter can again enjoy her toy that I was able to fix!
Mar 23, 2014 | LeapFrog Learn and Groove Musical Table
Both mini speakers are playing, but not getting any sound from the base box.... what might be happening?
The mini sub woofer's amplifier is not working but the other amps powering the left and right channels are ok.
Nov 28, 2013 | Klip Xtreme KSS-710 2.1 Stereo Speaker...
Bad sound quality on base speakerphone/answering machine
Hi , mostly in this case , the speaker in the base unit is defective . change the speaker.
Jul 09, 2012 | Panasonic KX TC1743B Cordless Phone
I have no sound coming from the tweeter in my b&w 602
Probably blown, tweeters are much more fragile than lower frequency drivers. If you know how to use an ohmmeter properly you can test it for continuity if it's a good quality meter (cheap ones can blow it out themselves in testing).
Jun 01, 2011 | B&W DM602 S3 Speaker
I'm having a problem hooking up these speakers... It has 4 hookups in the back of it which ones do I use? I just have a standard reciever to hook them up to...
look at this picture...
http://www.helpus2move.com/sold-items/b-w-dm602-s3-stereo-speakers-bowers-wilkins/
The vertical jumpers are removable if one wishes to BI-amp them. If not, leave them in place and connect your speaker wire conventionally - plus to plus, minus to minus.
The picture here...
http://community.whathifi.com/forums/post/265617.aspx
shows what to do if the jumpers are missing. Just fashion a short jumper for each to connect the top woth the bottom on each side.
Google bi amplification speakers if you're bi-curious. ;-)
Feb 02, 2011 | B&W DM602 S3 Speaker
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Top B&W Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
