Question about Konica Minolta bizhub C450P Laser Printer
Bizhub 550 error code c-3824 - Konica Minolta bizhub C450P Laser Printer
2 Suggested Answers
Bizhubman
  • 108 Answers
SOURCE: Have a BIZHUB 550 with a C-3724 error on it.
Fusing abnormally high temperature detection
The fuser section reached a temperature outside of safe operation. You can reset the error by: Turning the main switch off, leave the operation panel switch on, hold down the utility/counter key and turn the main switch on. As the screen loads you will see a black dot in the top right corner, at this point you can release the utility/counter key. The machine will take a minute to load. When the screen loads you will have a key that says "Trouble Reset" press it and you will get a "OK" message. Turn the main power off for 10 seconds and turn back on. If message returns you must replace the fuser. Attempt Trouble reset again at your own risk!! Fusers are a Fire Hazard
Posted on May 13, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Screen displaing this massge c-2253
If your copier machine is bizhub color 550 the error code refer to Color PC motor.
Feb 04, 2013 | Konica Minolta Office Equipment & Supplies
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
C-550 service code CD403
C-D403 code is a checksum error. Clean the connections and reseat the 2 ddr ram boards , If you still have the issue-replace the ram. That will fix it.
Aug 08, 2012 | Konica Minolta Bizhub C550 Color...
Error code f-26-3
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit
if this is a bizhub 222 the toner density error code would be c2557
May 10, 2012 | Konica Minolta Bizhub 222 Black and White...
P-21 and p-5 error message. and fully cyan color comes.
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Nov 27, 2011 | Konica Minolta bizhub C250 All-In-One...
Hi, I have a Konica Bizhub C451. There is a trouble code C-3824.Any advice to resolve the issue? Thanks Chris
Chris,
Turn off main power inside front cover insure that the sub power switch is pushed in on right side of the control panel. Hold down the Utility/counter button and turn on the machine hold down until screen shows trouble reset touch trouble reset go OK. Power off then wait 10 seconds power on. If the code comes back do not attempt another reset you are resetting the code for the fusing unit (The hot Part) It can catch on fire and that would ruin a perfectly good day! Have a technician look at it Good chance fusing unit needs replacing
Nov 03, 2010 | Konica Office Equipment & Supplies
Have a BIZHUB 550 with a C-3724 error on it. I had to select the 450 below as the 550 is not listed.
Apr 27, 2010 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta bizhub C450P Laser Printer Logo
1,270 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
