Question about Borland Turbo Assembler and Debugger 5.0 (LSM1350WWFS350) for PC
How can i install turbo assembler in windows 7 x64
2 Suggested Answers
SOURCE: 1. How to install and
I had similar issues with an old version of Turbo Pascal.
I used a program called DOSBox which emulates the older machines the packages were designed for.
http://www.dosbox.com/
It worked very well including full screen.
Posted on Mar 02, 2011
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
How can i install borland c on win 7 x64?
install a software called dosbox then install the turbo c++.
Feb 19, 2011 | Borland Turbo C++ 4.5 Full Version for PC
I just bought ASUS K61IC-x3, where is preloaded windows 7 home premium x64. Also I have 2 recovery disks from ASUS - windows 7 x64 and windows 7 x32. If I want to set up windows 7 x32, do I need to buy...
Windows 7 x32 recovery disk is used when you have to recover the Windows 7 x32 from a disaster. It works very well but when you want to install or setup Windows 7 x32you have to buy a new Windows 7 x32. Once it is setup and you use your system and you find that the Windows 7 x32 is making some serious problems then you use Window 7 x32 recovery disk. These disks are not the same.
Hope I answered the question.
Good Luck!
Jul 29, 2010 | ASUS K61ICX3 Notebook
How can i install turbo c in windows 7 x64
How to install Turbo C++ on Windows 7 We are providing detailed procedure how to install Turbo C++ on Windows 7. The very same procedure can be used on Win Vista. If you are running 64 bit version of Win 7, read this article. Users having Win 7 Pro and Win 7 Ultimate should use the virtual Windows XP Mode to install Turbo C++.
Installing Turbo C++ on Windows 7
1. Extract the zip files to: e.g. C:\TurboC
step1.jpg Extract zip files
2. Run the install: C:\TurboC\INSTALL.EXE
step2.jpg Run the install
3. Press Enter to continue
step3.jpg Press Enter to continue
4. Enter the Source drive: e.g.C and press Enter to continue
step4.jpg Enter the Source drive
5. Enter the Source path: \TURBOC and press Enter to continue
step5.jpg Enter the Source path
6. In directories specify where Turbo C files are copied. E.g. C:\TC . When done go to start instalation and press Enter
step6.jpg Specify where Turbo C++ files are copied
7. Succesfull instalation
step7.jpg Succesfull instalation
8. First launch from your destination e.g. C:\TC\BIN\TC.EXE
step8.jpg First launch from your destination
Jun 23, 2010 | Computers & Internet
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
TallyGenicom 8008 driver issue windows 7 x64
call the company Dascom they'll send you the x64 driver.
Mar 02, 2010 | TallyGenicom 8008 Laser Printer
WINDOWS 7 COMPATIBLE?
Yes, just use Windows 7 Update function to install proper drivers automatically. The drivers provided by Brother on CD do not work, though.
Feb 06, 2010 | Brother MFC 420CN All-In-One InkJet...
Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
Apr 28, 2009 | Computers & Internet
Borland Turbo Assembler and Debugger 5.0 (LSM1350WWFS350) for PC Logo
108 people viewed this question
Top Borland Computers & Internet Experts
k24674
Robin Hill
Robin Hill
Mishan Kasiparsad
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
