Question about IOGear MiniView GCS1804 KVM audio USB switch 4 ports (S7164231) KVM Switch
Keys get stuck after switching computers
My wireless keyboard keys get stuck sometimes after switching computers using the IOGear MiniView GCS1804 KVM switch. The behavior is identical as if you were holding down a key. The keyboard is basically useless.
  • Matt Rodenkirch Jan 17, 2013
    It wakes up after a few minutes and behaves correctly. It only occurs right after the KVM switch. The wireless mouse will also misbehave. The behavior is not unique to once computer (desktop) or the other (laptop). The same behavior happens on both.
firesnake09
  • 2923 Answers
SOURCE: All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Posted on Apr 06, 2009
SOURCE: IOGEAR KVM SWITCH WILL NOT TOGGLE BETWEEN COMPUTERS
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Posted on Apr 30, 2009
  • 5603 Answers
SOURCE: repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Posted on Jan 11, 2010
Testimonial: "Great idea, Fredy. I am having static problems all the time in my office. I will make a ground pad on my desk top. Thanks"
firesnake09
  • 2923 Answers
SOURCE: i have iogear miniview kvm (gcs62) keyboard works
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Posted on May 01, 2010
firesnake09
  • 2923 Answers
SOURCE: IOgear KVM not working with laptop
First, you have to make sure that the KVM switch is directly connected to your laptop, and NOT to a docking station.
This KVM switch is designed to work with direct connections to the computers.
Second, the light indicator on the KVM switch is not an indicator for power. It's an indicator to see which port is active. If your laptop is connected to port 2, but the focus of the KVM is in port 1, then the port 1 will have a light, not the port 2.
You may also refer to the user manual of the KVM.
Thank you!
Posted on May 18, 2010
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Repeated IOGear KVM switch failures
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Hooked up a iogear cgs62 wont allow me to log onto
II had one of those with no problem at all other than many KVM's dont allow you to use some of the many extra keys you get on some of the better keyboards. If thats what you mean by connect to internet then its a common drawback of cheaper end KVM's even some of the better ones dont support fancy keyboard buttons.
Aug 09, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Laptop will not connect properly
If possible directly connect the KVM cables to the laptop computer. Try to avoid connecting the KVM cables to a docking station. Also if your KVM has manual port selection buttons on the front of the KVM try holding that button for about five seconds when switching ports.
Jun 02, 2009 | IOGear MiniView III GCS1712 2-port KVM...
to toggle
Apr 11, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
Howto switch between computers with iogear gcs612a
A probably solution is to press the "Scroll Lock" button (usually at the top-right of the keyboard) twice in quick succession. Give it a try!
Mar 30, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
IOGear GCS62 2-port switching problem
I have a similar IOGear KVM switch. I use the Scroll Lock button twice to switch between PCs.
Hit the Scroll Lock button twice see if that does it for you.
Feb 09, 2008 | IOGear MiniView GCS62 2-port KVM Switch
KVM freeze, mouse and keyboard failure upon keypress
When ever trouble shooting a KVM that has a problem with one computer always swap the cables at the computer end -- that will tell you if you have a computer or KVM issue.
Nov 07, 2007 | IOGear MiniView GCS62 2-port KVM Switch
IOGear MiniView GCS1804  KVM  audio  USB switch  4 ports (S7164231) KVM Switch Logo
20 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
